Question about Whirlpool WTW4930XW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 10 Wash Cycles, 5 Selectable Water Levels and 800 RPM Maximum Spin Speed
Whirlpool4930xw0 won't spin, will drain
    Sergeant:
    Champion:
  • 282 Answers
Transmission timer belt solonoid ???? Take your pick. Motor is probably good because it drains
Good luck,
Marty
Posted on May 13, 2014
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
About every two weeks we have no hot water pressure. Cold water has pressure but not hot water.
Hi Nancy, What you have is called a VAPOR LOCK, What you can do is just what you are doing , But let's add a step to your wounderful job you are doing so far. Ok, yes OPEN your HOT FAUCET , DO Your steps but OPEN the RELIEF VALVE ( BLOW-OFF ) At heater unit. That's the TUBE that points to the floor by itself, OPEN UNTIL WATER comes out and your BANG sound happens,(may want to spin up slightly to put bucket under pipe) RELIEF VALVE pipe. This should help your problem. May need to repeat a couple of times in a row to complete your task. Hope this was helpful - Bill.
Jan 17, 2015 | Water Water Heaters
I have a whirpool energy star washer and the door is stuck in lock position. The lights that are on are spin and door lock
If you remove the bottom panel under the door, you can see a lever or tab that will allow you to open the door. Before you do that though, there is a drain plug that is visible. Remove the plug and get ready for WATER to come out. Have towels or wet vacuum cleaner ready. There will be a filter trap that is in the drain. Clean it out too.
Nov 28, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
Why does my washer wtw6200sw2 display an Ld code?
The Ld code is Long Drain. You might have a clogged hose. I had this problem once with mine. We had to empty the washer by hand and turn it on its front. Make sure you unplug it first! There is an elbow that I think was attached to the pump. We popped it off and it was clogged with dog fur (from washing dog bedding). Cleaned it out and put it back on and that took care of it. I found the diagram of the system online and suggest you look for it too - my memory isn't what it used to be - it'll tell you what to look for and where everything is. It could be the pump, too, but hopefully just a clogged hose.
Jun 07, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Wtw5500xw2 will add some water, senses for a very long time. Sometimes it makes it to the "wash" cycle but nothing happens. When you come back later the machine is off and the lid is unlocked as if it...
Un plug it for a few minutes or even overnight and plug back in, that will reboot the electronic control, if that doesn't fix it and you do not have a good honest local repair shop call Sears. Good Luck
Oct 12, 2013 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Washer does not drain
1.), Pump may be bad. Check voltage to water pump in Spin Cycle. If you have voltage at the pump, but it does not run, replace the pump.
2.) If you have voltage to the water pump, and can hear or feel it running, cut power off, and remove the boot which is directly below the wash bin. The boot empties into the water pump. You will need long needle nose pliers or better, use water pump pliers to remove the straps holding the rubber piping to the pump and the boot. Remove debris from the boot, i.e., bobby pins, coins, socks, pens, keys, etc.
3.) If no voltage comes to the pump in spin cycle, you may need a new timer.
4.) Install a new belt on the motor pulley. You will regret not replacing the belt later.
Feb 02, 2013 | Whirlpool Whirpool 3.5cu ft Top Load...
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
How to replace a magnesium rod on a John Wood electr. water tank?
You can buy these at any good hardware store- two types- Aluminium and manganese- if you replace and have a odor from water remove and replace with other. Really easy to do. Turn off water pressure to tank . Drain pressure at lowest tap in house. Put hose on drain spiggot of tank and drain off 1-2 gallons .Turn off electrical to tank. Unscrew old with socket- yes socket - do not use a pipe wrench.You will need a power bar Or good solid ratchet to remove and reinstall. Apply a pipe dope or teflon tape to new and srew in place- wrap tape counter clockwise or it will spin off as you turn in place and it will leak. Do not drain tank completely - you require this weight to keep tank from spinning as you remove and reinstall. After tightening slowly put pressure back on system - never shock pipes etc.Just as you do not slam your brakes- don't slam your pipes,Turn power back on after checking for leaks -tighten as required. Double check spiggot after removing hose as dirt can sometime cause a slow leak- monitor all areas for at least 3-5 mins and then check again at end of week. Also know that the lifespan of a tank should max at 15 yrs after that - replace or accept the flood when it happens. Good luck at poat me if you need me. Allen
Nov 26, 2008 | Water Heaters
Whirlpool WTW4930XW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 10 Wash Cycles, 5 Selectable Water Levels and 800 RPM Maximum Spin Speed Logo
54 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
80stech
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
