Question about RCA RP5420 Clock Radio
How to set time
Flashing number, no clock set
Clock will not set time
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Mar 02, 2015 | Kenmore Elite White 1.5 Cu. Ft. Convection...
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
How do I set the clock in my 2006 Equinox... nothing in the manual
check page 3-39
Setting the Time
To set the hour, press the clock button. The clock
symbol will appear on the audio display and the hour
number will flash. Then turn the ADJ knob to increase or
to decrease the hour. To set the minutes, press the
clock button again. The minute numbers will flash.
Then turn the ADJ knob to increase or to decrease
the minutes. The time can be set with the ignition on
or off.
To synchronize the time with an FM station broadcasting
Radio Data System (RDS) information, press and
release the clock button to enter the clock set mode,
then press and hold the clock button for three seconds
until UPDATED appears on the display. If the time
is not available from the station, NO TIME UPDATE will
appear on the display.
RDS time is broadcast once a minute. After tuning to an
RDS broadcast station, it may take a few minutes for
the time to update.
Nov 30, 2010 | 2006 Chevrolet Equinox
How to change the time on the clock
Without Radio Data Systems (RDS): To set the hour, press the clock button. The clock symbol will appear on the display and the hour number will flash. Then turn the ADJ knob to increase or todecrease. To set the minutes, press the clock button again. The minute numbers will flash. Then turn the ADJ knob to increase or to decrease. The time can be set with the ignition on or off.
With RDS: Same as without RDS unless you want to Sync. with a radio station. To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED appears on the display. If the time is not available from the station, NO UPDATE will appear on the display. RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it may take a few minutes for the time to update
Nov 29, 2010 | 2005 Chevrolet Cobalt
Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Nov 02, 2008 | Canon MP-25DV Calculator
No manual
Follow the procedure to set time/ clock.
Setting the clock
1. Press and hold CLOCK until
the hour flashes on the display.
2. Press << / >> to set the hour
and then press CLOCK to shift
to minute digits.
3. Press << / >> to set the minute.
4. Press PROG•SET to save
settings or STOP to quit setting.
You can download user manual at RCA Support.
Regards,
Sep 07, 2008 | RCA RS2663 Shelf System
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Calender
First Remove the clear tape from the battery compartment on the bottom. Second take a paper clip and press and hold the reset button for 5 seconds. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the date and press time set (M+/=) until it stops flashing. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the time and press time set (M+/=) until it stops flashing.
Apr 28, 2008 | Canon P23-DH Calculator
RCA RP5420 Clock Radio Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
