Question about Brother DCPJ315W AllInOne Inkjet Printer
Unable to init.AF printer brother DCP J315W
Unable to init. AF
Mix-it-up
  • 832 Answers
SOURCE: init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Posted on Sep 13, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother DCP 115C displays unable
press menu then start b/k-copy (mono) then fortimes arrow up button quickly after another. machine will switch to mainteance mode. press start bk copy.
What two digit error code does the machine display?
Post here again.
Posted on Mar 09, 2008
SOURCE: Brother DCP-135C - "Init unable AF"
sdfsd
Posted on Oct 14, 2008
  • 526 Answers
SOURCE: unable to int.AF by brother 330c
most likely you will need to take it in for service.
the problem with the AF error indicates a bad scanner assembly or possibly a cable that needs to be reconnected.
Before replacing the flatbed unit, disconnect and reseat the CIS flat cable at the Main
PCB. This will ensure that the issue is not being caused by debris in the connector.
open up the plastic cover that goes from the back to the middle of the unit. it looks like the cover goes from top to bottom, in the middles it turns to the left. take that out with a small flat blade screwdriver, pull the cable out and put it back in.
make sure you do this when the unit is not plugged in.
thanks
Posted on Aug 19, 2009
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
DCP-J315W shows "Unable to Init 4F"
Turn off the printer and unplug it from the power. Then press and hold the power button for 1 minute. Now release the button, plug in the printer and turn it on and see if the error clears.
If it doesn't fix the issue, you probably have to replace the cartridges. They will cost about $65. Good luck!
Feb 02, 2016 | Brother DCP Office Equipment & Supplies
Unable init. 50 on my Brother DCP-J315w ...what should i do
Any failure to initialise, print, clean error report usually indicates the waste ink chamber is full and the purge count has maxed out. You can remove the waste ink chamber, clean and replace the pads and refit it but seriously time consuming and messy. You should try the purge count reset first (do google search) eg this one
http://ref.topictimes.com/videos/tech/how-to-reset-purge-counter-on-brother-dcp-j315w-printer-full-1NzJwuCpVOc.html
If that works, you can keep using it but should clean the waste chamber. Or save the hassle and just buy a new machine :-)
Jan 05, 2015 | Brother DCP-J315W Inkjet Multifunction...
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Init unable AF, DCP185c
brother dcp 195c init unable af problem solve solution
Apr 04, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother DCPJ315W AllInOne Inkjet Printer Logo
243 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
