Question about AEG D2100-4 Electric Double Oven
Oven glass cleaning window
My aeg oven door shattered and it is 3 years old? What do you suggest I do?
barkencoa
  • 3463 Answers
SOURCE: my bottom oven is not heating up?
If it is an all electric fan assisted oven, and the fan is working o/k, then the oven element has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Posted on Dec 09, 2009
SOURCE: Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
Posted on May 09, 2010
  • 500 Answers
SOURCE: Where is the model no
Open the door, usually engraved within the door panel. Either on the sides or Top.
Most important number is called the PNC. If not found there, look for a sticker on the Oven Cabinet upper, after opening the door.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Posted on Feb 16, 2011
  • 9 Answers
SOURCE: how can I clean the
Not knowing what kind of dirt or grime is on the inside of the oven, I would recommend using one of these Whirlpool products. They all work great and they have different ones for different cleaning needs. Cleaners
http://www.pricedrightparts.com/categories/Accessories/Cleaners/?sort=featured&page=1
Joey
Posted on Jun 11, 2011
  • 2418 Answers
SOURCE: My oven is an AEG. The oven in your video is a
Open the door to the first stop, or what is called the "vent" location. This will be about 3 inches open. Lift up on the door and pull up and out. Set the door to the side and keep the arms on the bottom in the same position, do not let them close. Clean the door, when done and set the door back in the slots the same, open the door all the way, and close it. Done. Hope this helps Fix Ya up.
Posted on Jun 15, 2011
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
My inner door on my new world cooker exploded could it be i put it the wrong way round
Hi, it sounds like you put the door on yourself? The inner glass of my oven door (less than 1 year old) shattered when I put it in cleaning mode. We had to call a serviceman which fortunately was a part of the warranty we purchased and he said it could have been a microscopic fault in the glass, but he replaced it and it's been good to go. I've never heard of installing the door yourself for an oven, but even so, I just thought I would share our experience. It's a dangerous situation since it could shatter outwardly and hurt you or someone else so you might want to ask for a service person to come and look at it. Hope this helps!
Mar 13, 2012 | Ovens
I have only used my large oven three times and already the inside glass is brown. I have removed it but failed to clean it using all the regular cleaning materials. Can you suggest any way of cleaning...
Use a Stanley (or similar brand) window scraper. Hold it firmly and always flat against the glass and scrape that browm muck away. Be careful not to let the points on either side of the blade to dig in as this will scratch the glass.
This type of cleaning is carried out on ceramic/halogen hobs so is ok to use on interior slass oven doors.
Hope this helps
Jun 15, 2011 | AEG D2100-4 Electric Double Oven
Outside glass just shattered. While the oven had been on for about 5 minutes at around 160 degrees. Only 3 years old.
replace the glass as it needs it to vent door properly . without the glass door area will run to hot .. ..
Jul 11, 2010 | Ovens
Oven glass door shattered on the inside during self clean mode
The glass is replaceable. You need to get the exact glass replacement kit from the manufacturer. I had to have mine replaced about a year ago due to condensation between the 2 glass panels and was able to get the replacement for $0.00.
Suggest to Siemens that the glass on yours should not have shattered and therefore was probably defective and you may luck out and get the glass for free. It's worth a try.
Mar 18, 2010 | Siemens Ovens
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Inner glass door lower double ove
Many teasons for this to happen, no one has come up with a definitive solution for this,it just happens..
All you can do is have it replaced.
Mar 23, 2008 | Bosch HBN 455 Stainless Steel Electric...
AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Jan 04, 2008 | Ovens
AEG D2100-4 Electric Double Oven Logo
16 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
