Question about Brica Roll n Go Car Seat Transporter
Can I Fix Spring Loaded Mechanism on the Brica Roll n Go Car Seat Transporter?
Hi, I am trying to figure out how to get into the spring mechanism for the Wheel Lock on the car seat transporter. What happened: Wheeling my son out of the airport, I took the escalator down, and of course, I came in for a hard landing at the bottom and overstressed the spring on one of the wheel locks. I am trying to get into this location to see if i can re-attach the spring. I tried the removal of two axel pins to slide off wheels, but it might be that i have to separate the enclosure, with all its screws, to get to the spring. Can someone describe how to go about opening up the case and to re-attach a spring to the Brica Roll n Go Car Seat Transporter for educational purposes only?? Thank You for the Education Only, and any actual attempt is repair man/woman's liability.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
Contact Brica directly at:
BRICA Inc 500 West 5th Street Suite 220 Charlotte, NC 28202
USA 866.869.8257 (toll-free in USA)
www.brica.com
Posted on Nov 27, 2013
Front driver seat is stuck all the way back and will not go forward using release arm. non -electric 2009 camry
The mechanism is damaged or apart. Could be the spring mechanism is activated by this spring. Might need to remove seat to check and fix
May 22, 2017 | Toyota Camry Cars & Trucks
Have a Mr Coffee model #BVMC-PSTX91. The filter basket has a spring loaded release that has fallen off - how do I put back on? cannot figure out how to put the spring and extra plastic piece on?
without seeing it (a picture) that is a difficult question to respond to. it may have possibly broken or a piece of plastic needed to keep it in place broke - or the spring is defective. suggest get a new basket. (or go to the store, or find a neighbor with a similar model - and look at his basket, take a pic of the spring mechanism with your cellphone and go home to fix your own.)
regards,
Jan 27, 2017 | Coffee Makers & Espresso Machines
I removed front driver side seat in a 2001 suburan to recover when I replaced it the seat will not go frovtard or backward the lumbar worked what have I done wrong?
Hi Lee:
Should be no big issue.
The seat slides in "rails" and there is a spring loaded latch mechanism.
I'd start by removing the seat, turn it upside down, and make sure the latch is set in the "slider" part of the rails.
Happy day!
Nov 04, 2015 | 2001 Chevrolet Suburban
Graco alano not folding? the push and twist handle not turning?? so the stroller does not collapse or fold. how can i get it to fold. wife needs to travel back and i am not sure airline would allow her if...
Took a while but finally figured it out. Original thinking was that the problem is in the handle twist and release mechanism. The problem actually lies in the collar where the unit locks into place. If the stroller is in the open position it can't be fixed unless it's folded up. To open stroller without the twist handle -- locate both black spring loaded collars where it locks into place (approx outside where the seat and seat back meet). Manually pull both the collars up the shaft. The spring is tight and it may take an extra set of hands to get the right leverage. Once the unit is in the folded position -- flip the stroller upside down and blast WD-40 into the hole where the spring pins are and work the black collar up and down. The twist mechanism on the handle will now work. My daughter claims it didn't even work that good when the stroller was brand new and we saved the time and trouble of shipping the entire stroller and seat system back to Georgia just to let the Graco people decide what to do. Bottom line is that this mechanism design stinks from the get go. Hope this helps.
Oct 12, 2012 | Graco Alano Travel System Stroller -Greer
My middle seat belt is stuck in my bmw x5
seat belt might be folded over in the spring loaded mechanism of the seat belt, which is preventing it from moving freely
Aug 10, 2012 | 2005 BMW X5
Gear shift is loose and wobbles
Under the car on the on the gear shift lever is a spring this spring is ether missing or broken. Get under the car look in between the drivers seat area and the shift mechanism, maybe part of the spring is still hanging there. If not go to a local auto salvage yard and try to see where they fit.
Sep 05, 2011 | 2001 Ford Escort ZX2
Seat Position Cant be moved
The manual lever to release the seat is supposed to have a spring on it to return the release lever to the lock position, if the lever does not spring back when you let go of the seat adjustment lever then you know there is a missing, dis-connected, or broken return spring.
If this is the case try putting the seat where you want it to be and make sure that the adjustment lever returns to the lock position, now check to see if the seat will lock in with the adjustment lever in the lock position.
If it does lock in repair or replace the return spring.
Make sure that the adjustment lever is attached to the locking linkage and it does move the locking mechanism.
If it still does not lock into place then there is something wrong with the seat locking mechanism, and some WD-40 sprayed onto the seat rails and track might release a stuck mechanism, and if everything seems to be working alright, and you can see that the locking mechanism in the seat rail is moving in and out of the lock position, then the locking tabs are most likely sheered off and you will need to replace the seat.
Also look under the drivers side seat and compare the lever position and the linkage connections with the passenger side seat, and make sure that it is all operating like the drivers side seat.
Apr 28, 2010 | 2000 Renault Sportwagon
While putting the top up the spring loaded roll bars popped up
Hi , there is a special tool required to release the mechanism catch so you can push the roll over protection bars back to the opperation position , if you have a local dealer to you, they should be able to reset them at little or no cost , hope this helps , regards mark .
Jul 19, 2009 | 1998 BMW 3 Series
Passenger seat belt mechanism not working
yes for 20.00 you can replace it your self its a 32 Torx screw driveand its one bolt but before you take it out disconnect the battery?please rate my response thak you very much
Jan 03, 2009 | 1989 Toyota Camry
The cord won't rewind anymore.
all these rewinds are a pain! the rewind mechanism is a spring-loaded coil. fault is possibly that the cable is jammed and you may be able to free it by gently tugging and releasing. otherwise there is a problem with the spring and that is not worthwhile repairting
Mar 26, 2007 | Bosch BSG81313UC Premium Bagged Canister...
Brica Roll n Go Car Seat Transporter Logo
129 people viewed this question
Top Brica Baby Gear Experts
Dorel UK
Dorel UK
Are you a Brica Baby Gear Expert? Answer questions, earn points and help others
