Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Read Only folder
Hi I am not able to remove read only from any of my folders in Xp Prof, and no security options showing when i do share any folder or check their properties. The System is in workgroup and login through Administrator. Please give the solution ASAP. thnx
Hai shiva you are posted  your query is wrong, If the user account in winxp is limited then you get less option related to security and sharing. Login to admin account and change your files readonly or full permission and you can set any security and sharing futures.
thanking you
[email protected]
Posted on Oct 11, 2007
    Habit-Forming:
  • 188 Answers
1 st check virus on ur pc...if its ok then creat a new account from u r controle panal. i m sure u r problem will be solved man best regards mail- [email protected]
Posted on Oct 10, 2007
SOURCE:
I can't read/access my free agent contents
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
hop this helps
Nov 11, 2012 | Computers & Internet
Cannot add,edit,delete any files on my micro sd card,error shows it is a read-only memory card,
click start click to open on my computer you should see your SD card E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Right click the of your SD card (It should be E:/ or something)
Click permissions
hope this helps you
Feb 21, 2012 | Electronics - Others
Dear Sir/Madam, Having installed XP 5 years ago. I founded some of problem previously, such that, perform reinstall XP, meanwhile, I can't get back my data when reinstallation. And, I tried to change...
Please, try the following depending on the XP version you have:
For Windows XP Professional Edition, disable Simple file sharing:
Click Start, and then click My Computer. On the Tools menu, click Folder Options, and then click the View tab. In the Advanced Settings section, clear the Use simple file sharing (Recommended) check box. Click OK. Then, follow these steps:
  • Right-click the folder in question, and choose Properties.
  • Click the Security tab.
  • Click Add, and type in Administrators, click OK.
  • Select Administrators group that you've added now.
  • Put a checkmark near Full Control (Allow) in Permissions box.
  • Click OK.
For Windows XP Home Edition, you need to start Windows in Safe Mode in order to see the Security tab. Remaining steps are the same.
Once you add Administrators group and give them Full Control for the folder, theMake this Folder Private option is automatically disabled. Level 1 permissions are no longer in action.
Mar 21, 2011 | Microsoft Computers & Internet
I have a scan to a folder that is in waiting status. Can you explain how I get it into the folder? Are any new drivers required if using Windows 7 PCs to receive scans?
no no driver needed
some one may have changed the password so it cant authenticate so its waiting
ur folder needs to be shared with read and wright permisions turned on very important
shearing folder in w7 means nothing u have to go deeper in to shearing options to enable
"actual shearing" read and wright for all users
or u can go back to w xp much much easier to share
Nov 10, 2010 | Ricoh Aficio 2232C Color Copier
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
Target folder not accessible.
Perform the steps mentioned in the below article.
http://support.microsoft.com/kb/810881
Also, try this:
CAUSE
This issue may occur if the folder that you cannot open was created on an NTFS file system volume by using a previous installation of Windows, and then installing Windows XP. This issue may occur although you enter the correct user name and password. This issue occurs because the security ID for the user has changed. Although you use the same user name and password, your security ID no longer matches the security ID of the owner of the folder that you cannot open.
For example, although you use the same user name and password, you may no longer have permission to open the folder after you complete the following steps:
1. Before you install Windows XP Professional, you change the actual location, or target location, of the My Documents folder to another volume.
2. You format the primary partition.
3. You install Windows XP Professional.
RESOLUTION
To resolve this issue, you must turn off Simple File Sharing, and then take ownership of the folder:
1. Turn off Simple File Sharing:
a. Click Start, and then click My Computer.
b. On the Tools menu, click Folder Options, and then click the View tab.
c. Under Advanced Settings, click to clear the Use simple file sharing (Recommended) check box, and then click OK.
2. Right-click the folder that you want to take ownership of, and then click Properties.
3. Click the Security tab, and then click OK on the Security message, if one appears.
4. Click Advanced, and then click the Owner tab.
In the Name list, click your user name, Administrator if you are logged in as Administrator, or click the Administrators group.
If you want to take ownership of the contents of that folder, click to select the Replace owner on subcontainers and objects check box.
6. Click OK.
You may receive the following error message, where Folder is the name of the folder that you want to take ownership of:
You do not have permission to read the contents of directory Folder. Do you want to replace the directory permissions with permissions granting you Full Control? All permissions will be replaced if you press Yes.
7. Click Yes.
Click OK, and then reapply the permissions and security settings that you want for the folder and the folder contents.
Also, try to create a folder in external Hard Drive and then try to back up the data.
Jun 25, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
I am not able to share any local folder or drive from my computer. there is not option for file sharing and security. it is hidden not showing in folder properties. Any body help me??????? Regards: Hariom...
It will vary with your operating system. If you are using vista you will need to turn on file sharing in your control panel and then select the folder you want to share/right click/select properties/select sharing tab/select users
Sep 02, 2009 | Computers & Internet
Shared folder no long accesible xp and vista
Assuming that you have created a shard folder before, "Sharing Files and Folders" should be enabled on your machine.
Go to your Control Panel -> Folder Options adn click the "View" tab. Scroll all the way down and disable "Use simple file sharing (Recommended)".
Now the "Sharing and Security" option should appear again if you right-click a folder.
Microsoft has a write-up on this for general information. See here.
In regards to the possible Trojan - I would need the exact file name to find more information. What you can do from your end is to run an online scan with Kaspersky WebScanner.
Note: You should use Internet Explorer to run this scan, and you must disable your Anti Virus program during the scan.
Click the Accept button.
You will be prompted to install an ActiveX component from Kaspersky, Click Yes.
* The program will launch and then begin downloading the latest definition files:
* Once the files have been downloaded click on NEXT
* Now click on Scan Settings
* In the scan settings make that the following are selected:
o Scan using the following Anti-Virus database:
Extended (if available otherwise Standard)
o Scan Options:
Scan Archives
Scan Mail Bases
* Click OK
* Now under select a target to scan:
Select My Computer
* This will program will start and scan your system.
* The scan will take a while so be patient and let it run.
* Once the scan is complete it will display the results if your system has been infected.
o Now click on the View scan report link:
* Click the Save report as button
* Under Save as type, choose Text file (*.txt)
* Save the file to your desktop as Kaspersky.txt
* Copy and paste that information in your next post if you like.
If you have any more questions, or file sharing is still not working, just come back here and leave a comment - I'm happy to help.
Jul 14, 2009 | Computers & Internet
Error reading/writing on pen drive
You have to be the computers Administrator to change any values on any Hard Drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control. Click start click to open on my computer you should see your drive could be C: , or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your drive (It should be C:/ or something)
Click permissions
Jun 30, 2009 | Kensington Electronics - Others
Folder Read Only problem in windows xp professional
Hi This may help you http://support.microsoft.com/kb/304040 Good luck.
Aug 29, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
