Question about HP NetServer LP1000r
Usb boot on lp1000r ?
Any way to activate boot on usb ? Idea is I need to boot on a DVD drive...
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Go into the bios on startup
Posted on Nov 30, 2013
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Tip
How to Install windows 7 by using usb flash drive, pen driver or usb harddisk.
Friends i have seen thousand of laptop cd/dvd rom stops working very soon. then the quesion is how you do intall your os if it was corrupted.
follow my tip and install windows7 or vista in very simple way.
a) first insert your usb flash drive or hdd in usb port
b) then open commandprompt from accessories with rightclick run as administrator
c) you must know what is drive letter of your usb flash drive.
d) type DISKPART in command prompt and press enter
e) then type LISTDISK in command prompt
f) Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
g) Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
h) Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
i) Type another command given below to update the USB drive with BOOTMGR compatible code.
J) Copy your Windows 7/Vista DVD contents to the USB flash drive.
Eject the usb drive and select first boot device usb drive or usb hdd in motherboards bios.
enjoy... and please rate this trick.
on May 11, 2010 | Computers & Internet
Erc410m usb boot support
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
Nov 17, 2012 | Computers & Internet
RecoveryDisk Creator does not offer any disk selections to create
To access the recovery partition you need to boot up on a DVD with a partition manager on it, then set the hidden partition as "ACTIVE" and un-Active, the existing partition, then remove DVD and reboot, then the laptop will boot from the recovery partition and should autorun start the recovery procedure.
Jan 28, 2010 | Toshiba NB205-N311/W Netbook
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
SELECT DISK 1
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
Tip
Setup windows vista or windows 7 from pendrive
This tutorial will help you in creating a bootable USB drive of Windows Vista which you can use to install Vista in any system. It might become very useful when you don't have access to DVD drive.
1. First format your USB drive in NTFS file system. You can do it by attaching your USB drive to your system and then format it from My Computer window.
2. Now open Command Prompt window from Start menu. Right-click on Command Prompt entry in start menu and select "Run as administrator" option.
3. Now type diskpart in Command Prompt window and press Enter. It'll launch DiskPart program:
4. Now provide following command:
list volume
It'll show a list of all drives in your system. Look for your USB drive entry. As in the below screenshot, the USB drive is "G" which you can determine from its "Type" entry.
Now you have to select the USB drive volume by providing select volume no. command. Since in our case volume no. of USB drive is "Volume 4", the command would be:
select volume 4
Now we have to make this drive active. So provide active command:
active
Now exit from DiskPart using exit command.
5. Now we need to create Boot sector on USB drive. We'll use "bootsect.exe" utility for this task. You can find this utility in Windows Vista setup disk. It'll be present in "Boot" directory.
Now provide following command in Command Prompt:
bootsect /nt60 G:
Here G is drive letter of USB drive. Replace it with the correct drive letter if your system has some other letter for USB drive.
6. At last, copy all files/folders from Vista Setup DVD to your USB drive and you have done.
Now you can boot using your USB drive and can install Windows Vista in any system.
Thanks to Dave Glover for this info...
on Jan 17, 2010 | Computers & Internet
I brought a 2bd hand Zoostorm netbook with an 8 gig ssd card, how can I copy an operating system onto the card as the XP on it is faulty, and will not start. I have a USB 3.5 inch floppy, and a USB cd...
You need to make a bootable usb install for windows (these directions are for vista but should be the same for xp)
list volume
select volume 4
active
bootsect /nt60 G:
You can also see the directions here http://www.askvg.com/how-to-create-bootable-usb-drive-to-install-windows-vista/
Dec 26, 2009 | Computers & Internet
Tip
How To Create Bootable USB To Install Windows Vista
his tutorial will help you in creating a bootable USB drive ofWindows Vista which you can use to install Vista in any system. Itmight become very useful when you don't have access to DVD drive.
Use the tutorial available Here .
or
Do it using COMMAND PROMPT
1. First format your USB drive in NTFS file system. You can do it byattaching your USB drive to your system and then format it from MyComputer window.
2. Now open Command Prompt window from Start menu. Right-click onCommand Prompt entry in start menu and select "Run as administrator"option.
list volume
It'll show a list of all drives in your system. Look for your USB driveentry. As in the below screenshot, the USB drive is "G" which you candetermine from its "Type" entry.
Now you have to select the USB drive volume by providing select volumeno. command. Since in our case volume no. of USB drive is "Volume 4",the command would be:
select volume 4
active
5. Now we need to create Boot sector on USB drive. We'll use"bootsect.exe" utility for this task. You can find this utility inWindows Vista setup disk. It'll be present in "Boot" directory.
bootsect /nt60 G:
Here G is drive letter of USB drive. Replace it with the correct driveletter if your system has some other letter for USB drive.
on Dec 16, 2009 | Microsoft Windows Vista Ultimate Edition
HP NetServer LP1000r Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
