Question about Mitsubishi WD65835 65" HDTV
MITSUBISHI WD-65835 has power but no picture
When the power turned on there is no picture just blue screen
  • 927 Answers
SOURCE: mitsubishi ws65613 no picture or sound, blue screen only
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
Posted on Jul 17, 2008
  • 64 Answers
SOURCE: Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Posted on Aug 01, 2009
SOURCE: Mitsubishi WD 62827 pictures flashes colors
TAKE THE BACK OFF AND LEAVE IT OFF . NOW TRY IT. IT WORKED FOR ME STRANGE BUT IT WORKED
Posted on Nov 18, 2009
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
  • 94 Answers
SOURCE: Screen is blue with lighter blue lined flashing
defective DM assembly
Posted on May 28, 2010
Testimonial: "Yeah, we figured this was the problem - a friend has had the same experience. Thank you."
I have a mitsubishi 73 wd-73642 it had sound and I have picture but its dark and when I turn it off it just blinks yellow off and on what could be wrong
The dim picture is an indication that the Xenon lamp is at the end of life. Check the menu and settings to determine if the lamp needs replacing. Generally, they work well for 4000 hours then begin to get dimmer, slowly with time. Replacing the lamp is simple. You tube has videos that will show you how. The lamp should be less than $100 and can be ordered on line. I recommend you clean the DLP heat sink and the fans while you're at it to prevent overheating and eventual failure of the DLP chip. I had to replace the one in my WD-65835 Mitsubishi. Good luck.
Aug 26, 2016 | Mitsubishi Televison & Video
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
Mitsubishi WD-62525 BLUE SCREEN NO PICTURE NO SOUND
I had the same problem and I found that it was 2 caps on the power supply board. I had both caps replaced and it worked perfect. While it is apart see if any other caps are bad( if they are puffed up in the center they are bad).
Jun 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd-65835 not saving PerfectColor/Perfect Tint settings
I think you have to save it in the input selection, when you first turn on the set...
Mar 28, 2009 | Mitsubishi WD65835 65" HDTV
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD65835 65" HDTV Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
