Samsung fuzzy sw10k water running - Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Why the inlet valve is not stopping running water?
What happens with such electrically operated valves, is that a calcium (or other mineral buildup) prevents the rubber seals from stopping water flow. You need to replace the valve(s), or clean them thoroughly, using either LimeAway or CLR.
May 11, 2017 | Samsung WF337AA Front Load Washer
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
I am having ongoing problems with Samsung R519 laptop screen as it goes all fuzzy then goes normal then goes fuzzy again I have replaced the screen and screen cable and it still goes fuzzy then goes normal...
Have you updated the video driver in the laptop, there have been cases where the screen gives a variety of symptoms because the driver was outdated, if that fails! as crazy as this sounds do a fresh install of your operational system. I serviced a laptop with a flickering screen, I reloaded windows and got rid of the problem.
Apr 16, 2012 | Samsung R519-53S Notebook
Samsung LN-R329D has fuzzy video. Menus look fine.
thats a good assumption. try multiple sources and see if its just the one source. if its fuzzy, maybe youre using coax cable?? and the cable is bad or has poor signal. try tightening all the connections and making sure the cables are ok, let me know if this doesn't help.
Jun 06, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Water can't drain out properly
hi
i think all the fuzzy logic machines have an electric pump so it is maybe not running to pump the water out or i have had problems with the electronics that run the pump
cheers grantsreps
Sep 29, 2008 | LG Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
