Question about Reebok Vista Treadmill - RBTL13305
How do I get my I run reebok trademill to move
  • Stephanie Agugua
    Stephanie Agugua Nov 26, 2013
    How do I get the belt of my I run reebok trademill moving, everything seems to be working ok
    New Friend:
  • 326 Answers
If you push start and the belt does not move then it seems like the is a problem. This problem may be the LCB.
Posted on Dec 04, 2013
I broke the key,so can`t start the trademill.Can I buy new key?
yes, go to www.fitnessrepairparts.com or www.treadmillpartszone.com
God bless you
Jul 20, 2012 | Reebok 8000 ES Treadmill
I have a proform xp 550e trademill and i changed the motor control board because the motor start running and inmediadlly stops. after i installed the board the motor start running and stop some time after...
To calibrate the speed follow these steps.
Press stop and speed up and place the safety key in its spot.
release the stop and speed up.
Press stop again. The windows on the console (speed & time) will be all zeros.
Press speed up, the time window will increase. The belt should start to move. Increase this number to 85. This is maximum speed. Adjust the potentiometer to the correct maximum speed. The console will beep until the correct speed is adjusted (+ or - .2mph).
If the machine suddenly goes dead when in use, you may have a static electricity problem.
Check that the ground pin is present on the plug and check your outlet for a proper ground connection.
Dec 29, 2010 | Proform Exercise & Fitness
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
May 14, 2010 | Reebok Exercise & Fitness
How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Mar 07, 2010 | Reebok Exercise & Fitness
How do i unfold the reebok 8700 es treadmill? Just moved and have no idea. HELP!
We have a Reebok 8700 treadmill and need to get it downstairs-what is the easiest way to take a small amount apart ?
Feb 02, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Oct 25, 2009 | Reebok Rt1000 Treadmill Walking Belt
I-run treadmill belt does not run
Maybe check the troubleshooting section of your manual. If you don t have one, check here.
Feb 20, 2009 | Reebok New York Giants Eli Manning Jersey
Reebok Vista Treadmill - RBTL13305 Logo
198 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
