Question about Desa International HRC201-4 Remote Control
Remote will not turn logs on or off - using automatic or manual
Replaced batteries but still won't turn logs off auto or manual. Was working yesterday
    Top Expert:
  • Desa Interna... Master
  • 12,223 Answers
OPEN the r.control and clean the keypads for dirty, oxide, corrosion with contacts cleaner , tight the spring contacts batteries for better contact, use the plier and clean it.
and try again.
God bless you
Posted on Nov 25, 2013
How do I set automatic timer on AC1 Hozelock watering system?
incorrect operation. 1. Remove screws and back cover. 2. Insert two 1.5V 'C' Alkaline batteries. (Check + and - are correct.). IMPORTANT: Rechargeable batteries must not be used. 3. Replace batteries each season. (max 12 months use) MAINTAINING THE WATERPROOF SEAL 1. Ensure that rubber seal is positioned correctly. 2. Replace back cover and screw down tightly. 3. Repeat each time back cover is removed. HOW TO PROGRAMME THE TIMER There are two watering operations - Automatic and Manual. AUTOMATIC OPERATION Automatic ON 1. Turn dial clockwise to AUTO START at actual desired start time (e.g. To start watering each day at 15H00 you must set your AC1 when the actual time of day is 15H00). The timer has now memorised the auto start time until it is reset and will operate every day at this time. Use of manual ON or OFF does not cancel memory. 2. Turn dial anti-clockwise to: a) Chosen duration for once-a-day operation, or b) Chosen programme for all other watering frequencies (see table). The timer will now automatically run the selected program repeatedly until a new option is selected. GB 2 Automatic OFF Turn dial to Manual ON or OFF. If you wish to return to Automatic watering re-select the desired watering programme. NOTE your auto start time remains memorised until a new one is selected. Changing start time Turn dial clockwise to AUTO START at new chosen start time. Changing watering programme Turn dial to new programme. Do not turn dial to AUTO START unless a new start time is desired. MANUAL OPERATION Manual ON Turn dial anti-clockwise to ON. Water will flow for 60 minutes maximum or until turned to OFF setting. Note: After 60 minutes water shuts off. Knob will still point to ON and needs to be manually set to OFF or to desired number of automatic watering minutes. Manual OFF Turn dial clockwise to OFF. Note: Operation is only audible when valve opens and closes. To check that timer is working, switch to manual ON or OFF to hear valve operate. CONNECTING THE TIMER TO THE TAP Use supplied adapters if required. Tighten to ensure no leaks
Jun 25, 2018 | Hozelock Garden
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
2000 toyota avalon keyless remote won't open/close the car; checked with Auto Zone, fob is responding which means it is no battery, tried reprogaming and it stops when tried using fob, what else should...
2000 Avalon keyless remotes stopped working: solution Both keyless remotes for my 2000 Avalon stopped working. The batteries were good (I checked them with a volt-ohm meter). The Toyota dealer determined that the remote used most was defective and it tried to initialize the receiver in the car. This caused the second remote also not to work. The dealer reset the receiver (reinitialized it after first unplugging it), replaced the defective remote with a new one, and reprogrammed both remotes. Total cost: $225 labor, 164 for new remote. Later, another remote went bad. I just stopped using it.
Dec 13, 2012 | 2000 Toyota Avalon
My 1998 Silhouette back door won't unlock with key or fob
follow the steps and fix it. God bless you
    • 1 Enter the passenger side of the vehicle and look under the dashboard, beneath the glove box and near the floor mat. With the aid of a flashlight, locate a large panel, which is held in place by screws. Unscrew the panel manually or use a screwdriver if the screws are too tight.
    • 2 Locate the fuse panel. The panel houses long rows of fuses mounted to the panel. Consult the vehicle's owner manual to determine which of the fuses controls the automatic doors
    • 3 Remove the fuse that controls the automatic doors with a pair of fuse pliers, or carefully with a pair of regular pliers. Examine the fuse by shining the flashlight close against it. If the metal bar inside the fuse is broken, the fuse has been blown.
    • 4 Replace the blown fuse with a fuse of equal amperage. Push the new fuse in place, confirming it is a snug fit.
    • 5 Test the automatic doors before screwing the fuse panel cover back in place. If the doors close automatically after you manually give them a tug, the problem was the blown fuse. Replace the fuse panel cover under the glove box.
    • 6 Test the automatic doors with your remote control. If they do not open or close, the problem is with the remote. Pop the rear cover off of the remote with a screwdriver and replace the battery.
Oct 18, 2012 | 1998 Oldsmobile Silhouette
I tried the auto code search for my sentry rmc 10 and the device turned off but won't turn back on I have an older vizio
you must reset the code again use the code from your instr. manual. and proof again.
Retight the spring contacts battery with pliers for a good contacts
2) clean the contacts battery.
3) resolder the wires contacts battery
God bless you
Aug 02, 2012 | Televison & Video
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
I am trying to charge my cars battery but I am not sure where to put the 3 way switch.
Best solution is to use the Auto mode, since the unit will monitor the battery, and automatically switch to trickle charge when the battery is full. In the Auto mode, it won't overcharge the battery.
Feb 28, 2011 | Schumacher 10 Amp Fully Automatic/Manual...
I have a gas log fireplace with lmfp33pr log unit. The remote wont work. They have new batteries. The manual swirch will work. What do you think the problem is?
did you put new batteries in both the remote and the remote sensor box . if so you will need a new remote you can buy for about 100 bucks it includes the remote and remote sensor, its not hard to install . any gas log supplier can assist you
Dec 03, 2009 | Desa International Unvented Gas Space...
I replaced the battery in our HRC200 handheld it still does not work. We can turn the fireplace on with the manual control at the logs. The fireplace was used last season for the first time. Can you help?
The remote works once the right room temperature is
sensed (66F) by the remote, This is a room temperature
triggered remote.However, if the thermostat at the
remote becomes defective, then there is no way that the remote will function. You have to do it manually.
Oct 13, 2009 | Desa International HRC201-4 Remote Control
Does not turn off automatically
Turn remote "off", press and hold "Kg - Lbs" button, turn unit "On". Display should show "0", then "320" or model number. Unit was programmed to disable auto off. Works great now.
Thanks
Jun 01, 2009 | Health-O-Meter Healthometer 320KL Digital...
Desa International HRC201-4 Remote Control Logo
128 people viewed this question
Top Desa International Televison & Video Experts
Are you a Desa International Televison and Video Expert? Answer questions, earn points and help others
