Question about Cycling
Schwinn console 201
The wrong power adapter was used and now the console just beeps. do i need a new console or to replace the power plug wires?
2 Suggested Answers
wfservices
  • 262 Answers
SOURCE: schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
Posted on Feb 21, 2010
I have plugged in my schwinn 120 and it does not turn on. What may be some problems?
Check to see if power cables are plugged in, for any loose connections and or any visually crimped wires
You could also try disconnecting from outlet it is in and reconnecting to a new one just to make sure the outlet isn't the problem.
Make sure that your power adapter is supplying voltage to your unit, you could try connecting adapter to a machine you know that works or use a MultiMeter to check for appropriate voltage (please call us for assistance with MultiMeter tests if not sure how to run one.)
Insure your data cable is oriented properly, Small latch on connector should be lined up and snapped into place.
If these steps do not resolve your problem, please give our SportSmith Tech support Team a call and we would be happy to help or check out our Tech support center online
Phone Number is 888-713-2880
Or online http://www.sportsmith.net/supportsearch.aspx
Apr 26, 2015 | Schwinn Cycling
How can i get a power cord for my Swinn ex. bike?Estimated to be 5 Years old.
It would help to know what model bike You have because that model number can be given to any appliance parts dealer that You find locally, possibly even Sears, to get a replacement power adapter. I'm assuming Yours is like a small transformer that plugs into the wall outlet with a small cord that has a shiny metal pin on the end that plugs into Your Bike? Adapters for other Schwinn® and Nautilus® home fitness equipment can be ordered by phone at (800) 605-3369. Optional power adapter for the Schwinn® A40 elliptical, A10 and A15 upright bikes and A20 and A25 recumbent bikes. I hope that helps!
Feb 19, 2015 | Power Motorcycles
The digital read out on my 420 elliptical schwinn system blinks on and off. There is no error code
follow this steps and replace batteries too. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistanc
Oct 01, 2013 | Schwinn 420 Elliptical Trainer
My digital screen on my 420 elliptical schwinn blinks on and off
replace batteries and proceed with this steps and fix it. God bless you
  • 2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
  • Read more: http://www.ehow.com/how_6149016_troubleshoot-elliptical-machine.html#ixzz2gVxyHBXj
    Oct 01, 2013 | Exercise & Fitness
    Schwinn 420 elliptical
    follow this steps and replace batteries and clean the contacts batteries. God bless you
    • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    • 2
    Computer on my Schwinn Eliptical 418/428 keeps giving me an Error 1- Any ideas what this means.
    jlo621-
    An "Error 1" message is a generic electrical error code. This error code usually means one of several things: 1) the AC adapter needs replacing, 2) the wires connecting the power to the console need replacing, or 3) the console itself needs replacing. If the console has batteries, start by changing those. If this does not solve the problem, then check the AC adapter. If the problem persists, you're looking at a problem that might warrant the attention of a repair technician.
    Hope this helps.
    Regards,
    DIYpro
    Apr 29, 2011 | Sport & Outdoor - Others
    I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
    Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
    Jun 28, 2010 | Schwinn 430 Elliptical Trainer
    Schwinn recumbent bike 203 Ac adapter or batteries?
    It uses an AC adapter. You can visit:
    fitnessrepairparts.com
    This is where I am getting the AC parts for my 201.
    Mar 21, 2009 | Cycling
    Cycling Logo
    18 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    Andrew Taylor
    Andrew Taylor
    Are you a Cycling Expert? Answer questions, earn points and help others
