Question about GE Ovens
Ge spectra bake bar - GE Ovens
2 Suggested Answers
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
Can you replace the broiler ignitor with the oven ignitor for a ge spectra
Yes very commonly the same igniter that is used fro the bake is also the same one used fro the broil as well and as loong as the igniter looks the same it should work just fine.
GENE
Sep 18, 2011 | Ovens
I have an XL44 GE Spectra Oven/range. The cleaning feature no longer works and recently we have experienced the oven not getting to the desired temp for both Bake and Convection Bake. We set it to 350 and...
Page 22
Of the service manual shows your diagram. The oven sensor should read 1100 ohms @room temp (75f) All these new fangled electronically controlled ovens use a sensor. The negative temp coefficient sensor relays back changes in resistance whenever the temp changes inside the oven. If that sensor is not correct, open, or shorted to frame then the control will not function properly.
More here
Aug 23, 2011 | Ovens
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
I have a GE Profile Spectra XL44. When I turned my oven on to 375 it read 100 degrees for 10 mins. I open the door and there was no heat. I then tried the broiler to make sure it worked and the the element...
i wouldn't say it is "normal", but yes, the bake element in the bottom could have burned out again. it depends too on how often you use the oven. if you use it every day, chances are it will burn out quicker than say someone who only uses it once a week. you can check the element for a burn hole or a blister break. you can also check it for continuity with an ohm meter if you have one. hope this helps.
Nov 07, 2009 | GE Ovens
Yellow flames causing carbon buildup
If the burner bar has an adjustable slider for increasing or decreasing air into the bar.That would be it. If not then there is a defect with the gas valve or burner bar.
May 30, 2009 | GE JGRP17 Gas Single Oven
Don't know how to light GE Glow-Bar oven
Perhaps the oven ignitor (glow bar) is defective. To test, check the voltage going to the ignitor when you turn on the oven to bake. If you have 110 volts testing with a voltage meter, replace the ignitor. If you do not have voltage, trougleshoot backwards to see where you have voltage in but not out.
If I can help further, I am here.
Eric Campion
Mar 04, 2009 | GE JGRP17 Gas Single Oven
Bake ignitor Location
ok jimmy not as bad as you think you access it through the oven cavity remove all the racks look for two screws on the bottom panel i believe they are at the front remove them then remove the bottom panel next you will see a lame spreader which is an angled plate remove it then you will see the burner bar at the back is the ignighter just match it with the new one
Feb 11, 2009 | GE Ovens
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
My ge spectra stove bake element is not heating
Dec 18, 2007 | GE JKP20 Electric Single Oven
Ovens Logo
13 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
