Question about Konica Minolta bizhub Office Equipment & Supplies
I have a konica minolta c450 and it displayed error c-d 370. I cleared it using 0-7-1-3-9 as instructed but on switching on the machine,on the screen it asked me to enter serial number and call ser
I have a konica minolta c450 and it displayed error c-d 370. But afterd clearing the error it asked to enter serial number and call service engineer,
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
goalie39
  • 469 Answers
SOURCE: Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
Posted on May 11, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
  • 158 Answers
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Posted on Nov 16, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Error p 5 konica milnolta bizhub c450
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
C450 c-0204
Pull out the cassette and check the paper capacity not to exceed the maximium level. Clear any irregular or untidy paper if any.
Feb 24, 2014 | Konica Minolta Office Equipment & Supplies
Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
Feb 06, 2014 | Konica Minolta bizhub Office Equipment &...
per last, Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
I have a konica Minolta bizhub c450 it was running fine until there was a power outage when powered on the device read an error code CD370 and the language was in chinese or japanese after clearing the...
you should be able to get into service via trouble reset hold utility button while turning on copier when you get to trouble reset screen do the stop 0 stop 0 1 and that should get you in. You might need to put the stock firmware on to cure the fault. If you need anymore help i can look into it for you.
Oct 30, 2013 | Konica Minolta bizhub Office Equipment &...
Enter serial number
Your memory (NAVram) is full, you need to clear it.
Oct 30, 2013 | Konica Minolta Office Equipment & Supplies
Please what is the solution for C-D370 on konica minolta bizhub C450
The error code is for the NVRAM. You could try this key combination: Stop 0 7 1 3 9. Press * Restart the machine. It should be fine. CAUTION: The meter readings will be reset to 0. Any settings you had before will also be cleared!
Jul 09, 2013 | Office Equipment & Supplies
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
171 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
