Question about Garden
Oil coming out of air filter
I have a Troy Bilt lawn mower model 11AA26M011. It runs great, starts easy. Oil level is good. While mowing the lawn it started smoking and oil started coming out of the air filter leaving a small puddle of oil. I cleaned everything up and it ran fine. After mowing the lawn several times with no problem, it did it again.
    Genius:
  • 1,198 Answers
Look for a crankcase ventilation tube or such, It may be covered with grass dust and stuff, is probably a sponge to keep dust out of the motor. Rinse it out, and make sure the airway is clear.
Posted on Nov 25, 2013
4 Suggested Answers
highspeedsan
  • 61 Answers
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Posted on Apr 26, 2009
  • 82 Answers
SOURCE: Lawn mower died. Pull rope locked up
remove the spark plug and try to pull the rope. Sometimes the coil can get loose and wedge against the flywheel. if that's not the problem then pour a little oile in the spark plug hole, let it set a bit, if it still won't turn over then you have an internal engine problems. Not very common but it can happen
Posted on May 09, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
Starts then dies
Check oil level. all mowers have oil level cutoff. 30w oil. Remove air cleaner, try to start. Replace filter if dirty.
May 15, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower 6.75 hp smoking too much oil
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
May 19, 2010 | RTO Lawn Boy 6.75hp Mower
Oli spils when lawn mover starts
Check your oil level in the engine, normally if oil starts coming out of the air filter, it means you have too much oil in the crankcase. Drain your crankcase to make it the right level, be sure to check you oil level in the engine on level ground. I hope this helped, Good Luck Please rate me, Thanks
Dec 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy built lawn tractor keeps stalling out while mowing lawn. It starts up again, but mowes for a couple of minutes then stalls out.
Have you checked your air filter..it sounds like it could be dirty and needs replacing..if this dont help..just comment back and i will get it..and i will help you further..Keith
Jul 04, 2009 | Garden
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
