Driver laptop gateway 7324
How to reset password to unlock hard drive
    Top Expert:
  • Computers & ... Master
  • 25,695 Answers
If the hard drive has a password on it, that means it is encrypted and a new OS will have to be installed.
Posted on Nov 25, 2013
  • 112 Answers
SOURCE: bio's password reset
Several options:
http://xtreview.com/review113.htm
http://www.pwcrack.com/bios.shtml
worse-case scenario: replace motherboard
Posted on May 23, 2009
graysand
  • 558 Answers
SOURCE: How do you tighten the hinges for a gateway 7324 laptop?
Remember before you do any work to remove the battery and the power supply.You will have to remove the Lcd Bazel.There should be some rubber covers over the screws on the bazel.Remove and put them in a safe place as you will have to replace them.Once you have removed the screws use your finger to gently pry away the bazel.Look towards the base you will see the screws tighten them and this should take care of it.
good luck
Posted on Sep 15, 2009
prasant1990
  • 59 Answers
SOURCE: Reset Bios Password
At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory.
However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
O 70 17
O 71 17
Q
PHOENIX BIOS
O 70 FF
O 71 17
Q
GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
O 70 2E
O 71 FF
Q
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Using the jumpers
The canonical way to flash the BIOS via hardware is to plug, unplug, or switch a jumper on the motherboard (for "switching a jumper" I mean that you find a jumper that joins the central pin and a side pin of a group of three pins, you should then unplug the jumper and then plug it to the central pin and to the pin on the opposite side, so if the jumper is normally on position 1-2, you have to put it on position 2-3, or vice versa). This jumper is not always located near to the BIOS, but could be anywhere on the motherboard.
To find the correct jumper you should read the motherboard's manual.
Once you've located the correct jumper, switch it (or plug or unplug it, depending from what the manual says) while the computer is turned OFF. Wait a couple of seconds then put the jumper back to its original position. In some motherboards it may happen that the computer will automatically turn itself on, after flashing the BIOS. In this case, turn it off, and put the jumper back to its original position, then turn it on again. Other motherboards require you turn the computer on for a few seconds to flash the BIOS.
If you don't have the motherboard's manual, you'll have to "brute force" it... trying out all the jumpers. In this case, try first the isolated ones (not in a group), the ones near to the BIOS, and the ones you can switch (as I explained before). If all them fail, try all the others. However, you must modify the status of only one jumper per attempt, otherwise you could damage the motherboard (since you don't know what the jumper you modified is actually meant for). If the password request screen still appear, try another one.
If after flashing the BIOS, the computer won't boot when you turn it on, turn it off, and wait some seconds before to retry.
Posted on Jul 07, 2010
engr_alam198
SOURCE: how to unlock toshiba satellite laptop BIOS and HDD
toshiba l500 model laptop i can remove hdd passwoard
Posted on Oct 03, 2012
  • 64 Answers
SOURCE: NEED TO UNLOCK PASSWORD TO LAPTOP
Forgot laptop password? Crack login password!
Posted on Oct 16, 2013
Bought a laptop at auction but don't have password to open up
Have a read.
How to Reset Forgotten Password on Gateway Laptop www.windowspasswordsrecovery.com > Resource > Password
A Gateway password is the password that you must enter to log into the administrator or user account on your Gateway laptop or ... You Forgot Gateway Laptop Password?
  • 4 Workable Ways to Recover Gateway Vista password www.windowspasswordsrecovery.com > ... > Windows Vista Password
    Lost Gateway Laptop password? ... 4 Workable Ways to Recover Gateway Vista password. ... you should login Gateway Desktop and enter User Accounts by clicking ...
  • How to Reset or recover the lost Gateway Laptop Windows ... www.windowsloginrecovery.com/reset-gateway-windows-7-password.html
    Forgot your Gateway laptop password? ... How To Get Gateway Windows 7 password reset or ... Reset Admin or other user account passwords with USB Flash ...
  • Gateway Official Site: Worldwide support.gateway.com/s/Mobile/Gateway/M320/3501937sp34.shtml
    Gateway.com Support. Select a country or region. Americas. Canada (English) Canada (Fran?ais) United States; Mexico; Argentina; Brasil; Colombia; Panama; Peru ...
  • Forgot Administrator Password for Your Gateway Computer ... www.top-password.com/knowledge/reset-gateway-password.html
    Forgot Windows login password for your Gateway computer? ... Forgot Windows 8 Password; Reset Windows 7 Password; Bypass Windows 7 Password; Windows Password ...
  • GATEWAY Bios Password, Unlock Your Laptop in minutes gateway-bios-password.biosremoval.com
    Here is the solution to unlock Gateway Bios Password, Gateway Password, Gateway user ... 2013, Gateway Bios Password, Gateway Password ... M320, M320S, M320X ...
  • How to Reset Gateway Laptop Password Windows 7 - Unlock ... www.youtube.com/watch?v=EUx5AjTCLFw
    • BY LYNDON MOSES
    • 3 MIN
    • 14K VIEWS
    • ADDED 2013-11-25
    Video embedded · How to Reset Gateway Laptop ... This may be the fastest way to recover a lost Windows 7 password that ... How to crack windows 7 "user login" password ...
  • Feb 11, 2016 | Gateway M320X Notebook
    Tip
    How to Reset Gateway Password?
    How to reset Gateway laptop password? I forgot my PC password Gateway Windows 7, I want to unlock laptop password urgently! Can you help me recover my lost power on password for Gateway? Now, we together share some ways to remove Gateway admin password.
    Optional 1: DIY a CD/DVD/USB password reset disk instantly to recover lost Gateway password
    The method is the most effective solution to get out of Windows password problem. It just needs burn an .iso image file to one of these media. Now, take one of most popular Windows Password Recovery tool as example:
    A. Download Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
    B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
    C. Reset a new Gateway password.
    Whatever for Gateway Windows 7, Vista, XP, Server 2000, Server 2008, etc. the above Ainorsoft Windows Password Recovery has its different versions to suit for these OS.
    Optional 2: Gateway password recovery disk helps remove lost laptop password
    It is the most convenient way to retrieve Gateway PC password and while, is maybe suitable for little part of computer users. The Gateway recovery disks should be created once our Windows account is created. Also, one account password responds to one password reset disk. Take Gateway Windows 7 as example:
    A. Insert a CD/DVD/USB Flash Drive into the driver.
    B. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.
    C. On the left pane, select "Create a password reset disk" - "Forgotten Password Wizard".
    D. Click "Next" and follow the Wizard to create password reset disk.
    Now, the Gateway Windows 7 password recovery disk is created. When we need break Gateway Win 7 laptop or notebook password on the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will help you create a new password to override lost Gateway password.
    Optional 3: Reset Gateway password by accounts with administrative privileges
    Accounts with administrative rights or the default and built-in account can help us to remove Gateway password. Take Gateway Windows XP as example, there is a default Administrator account. We can use it to unlock locked account if this built-in account is still blank or accessible.
    A. Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.
    B. Start -> Control Panel -> Administrative Tools -> Computer Management -> Local Users and Groups -> folder Users
    C. Right click the account user name which password was lost, and then click Set Password -> Reset password -> keep New Password and Confirm Password blank.
    D. Right-click locked account and select Reset password.
    E. After finished, restart PC and login.
    Optional 4: Ophcrack Windows Password Recovery software
    Ophcrack is a free Windows password recovery tool which only works for passwords with less than 14 individual characteristics.
    A. Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.
    B. Insert the CD into the locked computer and restart it.
    C. When computer starts, we have to press the correct key to enter the boot menu.
    D. After select the drive that the CD is in at start menu, do as the following instructions.
    If we forgot Gateway laptop password and need Gateway password reset, we can easily reset Windows 7, XP, Vista password on Gateway PC or netbook with the above 4 optional methods.
    Source: http://windowspasswordrecovery.net/article/gateway-password-reset.html
    on May 06, 2011 | Computers & Internet
    HDD password is frozen on windows 7
    These WEB sites can remove the hard drive password.
    HARD DRIVE PASSWORD UNLOCKING - Purchase
    http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
    http://www.hddunlock.com/download/
    Mar 20, 2013 | Gateway Computers & Internet
    Gateway cx2610 laptop hd password protected cant locate cmos battery
    These WEB sites may help you remove the hard disk password.
    Dec 01, 2012 | Gateway CX2610 Notebook
    Gatewaycomputer7322gz hdd locked need password
    Hard disk passwords are difficult to remove but these WEB sites maybe able to help you.
    Nov 06, 2012 | Gateway 7322GZ Notebook
    Trying to remove or reset hdd password, cannot get to bios
    Hard drive password is difficult to remove. These WEB sites maybe able to help you.
    http://www.hddunlock.com/download/ .
    Sep 10, 2012 | Gateway MX Computers & Internet
    Hdd password for mx6421
    These WEB site may help unlock the hard drive.
    Sep 05, 2012 | Gateway MX6421 Notebook
    Need to unlock gateway 7330GZ hdd
    So who put the password on it? 99% of the time if there is a Hard Drive Password and the person in possession of the laptop don't know the password, the laptop is stolen. The original owner put the password lock on the hard drive to keep thieves from getting to sensitive data. The owner could have set the password remotely once the laptop was stolen. Your system is toast. The only remedy is to get the original owner to remove the password.
    Apr 07, 2012 | Gateway 7330GZ Notebook
    Hdd password reset on gatewaym-1624
    HDD password is a security measure against theft. Contact Gateway and verify you are the owner. Itherwise you need a new hard drive and reload of all software/drivers.
    Feb 16, 2010 | Gateway M-1624 Notebook
    Asking password before booting
    Sounds like somebody installed a hard drive password, and there is no way to get around it but to replace the hard drive and start over.
    Dec 28, 2008 | IBM ThinkPad T23 2647 Notebook
    Computers & Internet Logo
    23 people viewed this question
    David Payne
    David Payne
