Question about Gemmy Home
Christmas snow globe ..how do I change light bulb?
Im trying to figure out how to change the light bulbs?
MicrowaveSvc
  • 9098 Answers
SOURCE: Light Bulb Change
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Feb 03, 2009
  • 105 Answers
SOURCE: replacement of oven light bulb
Just pop the wire holder off to one side (it pivots) and the globe will come out.
Posted on Apr 08, 2009
SOURCE: Cant remove Globe to change light bulb on Hampton Bay ceiling fan
twist counterclockwise (looking up at it) on glass firmly and carefully, the globe functions like a screw
Posted on Jun 10, 2009
SOURCE: Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Posted on Oct 10, 2009
SOURCE: change a lightbulb on a Mr. Christmas Holiday
There are two tabs that hold the top of the lighthouse on; push in gently just above one of the tabs, and it should release the top of the lighthouse. The red and green covers just pop off.
Posted on Dec 23, 2009
Where do I get a new light bulb for the Cannon PC-6RE Copier? All copies are now a completely black sheet.
See if you can get the globe out of the machine and take it to a specialist globe / lighting shop. Im sure they would have one or know where to get it. Once you have the globe out, you should be able to see written on the globe , the make and type of globe and the wattage. Go online once you have this info and have a look. I doubt if Canon make their own globe for a printer, they would have someone else make it.
Feb 18, 2015 | Cannon Office Equipment & Supplies
Christmas lights won't blink
Each section of lights needs a special bulb called a 'flasher'. This bulb is usually identified by a red tip. If the flasher bulb is not working properly, the section of lights won't blink. Replace the flasher bulb.
Nov 29, 2011 | Christmas Lights Etc Santa's Toy Truck
How to cut to size christmas light strings
If you cut the line it would reqier less power so inturn may blow the globes.. it can be done but i woulden advise it if you dont know your electronic basics...
Oct 21, 2011 | Christmas Lights Etc Santa's Toy Truck
I cant figure out how to get at the light bulb to change it
Try pulling the globe straight down. I believe that this model has spring loaded clips holding the globe on the base.
--W/D--
Feb 18, 2011 | Hampton Bay 52 In. Brushed Nickel Romano...
I have lost my instructions and cannot figure out how to replace the burned out light bulb in my Minka Aire F603 ceiling fan unit; I can't figure out how to get to the bulb - can't figure out how to get...
Hi Bill. So far I have not been able to find a manual, but I will keep looking. In the mean time, if you want to give it a try, it appears to me that the circular piece that has the fingers that hold the light globe is probably put in place to hold the globe by a "turning" motion. If you were to reach up and grab this ring and gently turn it counter clock wise I bet it would turn perhaps 1-3 inches and disengage the fan body. Makes sense that the manufacturer would make it easy to change light bulbs and viewing the fan, this would be about the easiest way to do it. I would assume the glass globe is NOT fastened to this ring in any manner, so if you do decide to try this, be ready to have the glass globe release from the holding ring.
I will let you know when/if I find a manual. If you decide to try my solution and are satisfied with it, I would appreciate a Thumbs Up rating from you. BTW, nice fan. Paul
Oct 08, 2010 | Minka F603-WH Ceiling Fan
1/2 strand of christmas lights do not come on
There's a blown bulb.. take a spare globe & pull out one of the lights that is'nt working on the strand and put the spare one in if the string doesent light up try the next one and so on..
Dec 31, 2009 | Christmas Lights Etc Santa's Toy Truck
How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
  1. push it up and turn (like when you open a medicine bottle.
  2. try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
May 31, 2009 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
How do I change the light bulb
I think that the plastic round will pop out of the center--held in by tabs?
Mar 02, 2009 | Broan-NuTone QT100L Fan
Changing light bulbs in Hampton Bay 60 in. Miramar Fan
You have to unscrew the small openings on top of the housing where the motor is to access the small nightlight bulbs.
Jan 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Home Logo
283 people viewed this question
Top Gemmy Home Experts
john h
Tom Chichester
Are you a Gemmy Home Expert? Answer questions, earn points and help others
