Question about Sport & Outdoor - Others
Crosman T4 Manual
The canister leaks right away when I install it .O ring must be no more good . I only used 7 or 8 cartridge .Can you help me install a new o ring ? Ray .L.
magoo23
  • 22 Answers
SOURCE: CO2 cartridge leaks down in seconds in a crosman model 357 (older model six shot)
Frank i would love to help you, i'm an airgun enthusiast too. please tell me the model crosman you're shooting at the moment and i would love to walk you through this, if you need repairs i'll also try to help get you in touch with parts or some ideas for service if it's needed.
Posted on May 06, 2008
SOURCE: print cartridges
Remove both print cartridges.  Install the black cartridge and close the lid.  It should recognize the cartridge and tell you to install the color cartridge.  Open the printer back up and install the color ink, then close the lid.  I fought with this problem forever until I figured this out.
Posted on May 26, 2008
xptareq2000
  • 1447 Answers
SOURCE: The install cartridge message won't go away
yes it is problem your copier machanical problem.if it is original cartridge this printer or cartridge problem
Posted on Aug 17, 2009
jyackle5
  • 8197 Answers
SOURCE: My Thane Q grill leaks propane when I screw in a
go to this site http://www.thane.com/manuals/manuals.php then scroll down to the Thane Q-BBQ Grill manual, select it and it will open in PDF2_bing.gif formate so you will have a free instant manual.. if this helps please rate me and let me know..thanks and good luck!
Posted on Apr 18, 2010
SOURCE: My crosman 1008 repeatair valve is leaking.
Try running a couple drops of transmission fluid through the air system. It seems to work well on paintball guns.
Posted on Dec 31, 2010
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
How do I open my crosman t4 pellet gun?
There is a lever on the left side of the gun, towards the rear, up by the slide. Push down on it and the port for the round magazine will open on the right side. If you are trying to replace the CO2 cartridge, the back strap (rear portion of the grip) lifts up from the bottom.
Oct 06, 2014 | Optics
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
I have a crosman model 380, .22 cal pellgun that leaks when the co2 is inserted and punctured. I cant see any seal or O-ring at the puncture point. What is missing and how can I fix the problem. Matt
I have the same problem and have dealt with guns for 40 years !
I am glad to see that the other folks have some realistic and innovative ideas of how to remedy this problem.
I went to Lowe\'s on a "tip" and found some very small \'O\' Rings for $ 0.87 for two and I am experimenting with them. The first try I couldn\'t crank the screw down far enough to even puncture the CO2 Cartidge. Using a larger screwdriver I finally managed to puncture the cartidge, unfortunately it still leaked but waas a much smaller leak.
Still experimenting.
I am going on-line to locate the Model 380 Schematic diagram which is where I ran int this site.
Good luck all !
Aug 17, 2011 | Crosman (4032)
Crosman c11 - co2 cartridge leaks out.
This typically occurs when the o-ring seal near the needle to puncture the container is missin or damaged. Use a flash light and see if you can inspect the canister valve location to cehck the o-ring.
You may need to take the unit apart to check the parts. If you do not feel comfortable doing so then you need to send it for service or have someone that can work on it do so.
Mar 21, 2011 | Crosman (4032)
My rifle leaks air when i screw in the co2 cartridge is there something i can do
yes you can buy the srevice kit with all the "O" rings you need to service it from crosman
Nov 27, 2010 | Crosman Optics
Info on repair crosman 150 air pistol
This is better known as a Crossman Air Pistol and it is powered by co2 cartridges that will not last too long once puntured/installed in the pistol, they tend to leak out within less then a day if not being used so try to use the cartridge once you have it in place.
Some fire BB's and some fire pellets.
Wear protective eye wear and clothing and always fire down range never point any pistol at anyone when handling it keep your fingers off the trigger and point up or down range.
Happy Target Practicing!!
Sep 29, 2009 | Computers & Internet
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
How do I change oil filter cartridge on 1995 BMW 325is?
I would first clean up the oil around the housing with brake cleaner. Take the car for a quick run and see where the oil is coming from.
If the housing looks good, then simply take the cap off of the oil filter housing. Remove the existing filter and discard the o-rings. Make sure you lubricate the new o-rings with some oil before installation. This could be why it is leaking now. It may have been overlooked.
Once the o-ring is seated drop in the new filter and replace the housing cap. Tighten the cap to 18 ft lbs. Start the engine, making sure the warning light goes out, showing you have oil pressure.
If your oil is that new then I would not bother with a changeover.
I hope this helps. It is an easy filter to change. BMW doesn't make too many things easy.
Good luck
Jun 21, 2008 | 1995 BMW 3 Series
Sport & Outdoor - Others Logo
42 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
