Question about ProForm XP 210 Upright Exercise Bike
Proform xp 210 u display failed - ProForm XP 210 Upright Exercise Bike
The console will not turn off with new batteries
Leave the machine for a few hours. You may not be giving it enough time. Also you may inadvertently changed the settings. Check that.
Sep 15, 2013 | ProForm XP 210 Upright Exercise Bike
Proform Treadmill Memory Test Flash Fail
Run the software calibration for easy diagnostic and fix it.
Go under the Hood cover and see the instruction.
God bless you
Jul 07, 2013 | Exercise & Fitness
I have a proform xp trainer 580 . The display works but the actual walking belt doesnt move.
please see the video and fix it according.God bless youThis happen because the lack of maintenance schedule .
Apr 04, 2013 | Proform XP 580 Trainer Treadmill
Proform xp 580 - Occassionally, any button i push simply beeps, and nothing else happens, no response from the panel.
Step 1:
please replace the old batteries with a new ones, with the same mark+same polarity+full charge.
Step 2:
adjust the REED switch, see the diagram attached, test for open or faulty, clean it, and tight the connector very well .
Step 3:
tight all connector a) ribbon cable inside for keypads b) upper connectors board display vs lower connector main board.
God bless you
Jan 04, 2013 | Proform XP 580 Trainer Treadmill
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 620 treadmill and the control panel keeps shutting off and on. i can start walking then it shuts off and then seconds later it comes back on
adjust the sensor switch first.2) change the batteries if have it.3)tight the flexible cable vs display board.4) tight the connector from display board vs lower board.
If the problem persist.you must test the following:1) Test the main motor.2) See if the drive belt is broken, loose, or slip3)finally the main motor board possible is faulty
see block diagram12_1_2011_11_16_04_pm.gif12_1_2011_11_16_27_pm.gifgood luck.
sincerely.
e.cuadramanagua,nicaragua
Dec 01, 2011 | Proform XP Weight Loss 620 Treadmill
I am getting an error on the console of my Proform XP Treadmill that reads: checksum: fail...what does this mean and how can I fix this?
The Display Console is the brain center of the Treadmill. .. Checksum Error Xxxx . Rom failure to due a possible cause 8Vdc. by short circuit inside..Faulty display consolel PCB.
Since the treadmill is a computer has the same components like a PC.
Nov 16, 2011 | Exercise & Fitness
My proform xp 620 treadmill starts up fine and I can walk on it up to 4 mph. However, when I try to go up to 5 mph, the belt stops moving and the display screen goes blank.
1) adjust sensor reed switch or optical disk by 1/8" aprox and replace if neccesary after if the problem persist.
Chech the plug connector console panel vs. and controller board. If everything is wrong the console panel is bad.
Aug 22, 2011 | Proform XP Weight Loss 620 Treadmill
I have a proform xp 550s treadmill. The belt
change drive belt proform xp 550s treadmill
Aug 26, 2009 | Exercise & Fitness
ProForm XP 210 Upright Exercise Bike Logo
Top ProForm XP Exercise & Fitness Experts
greg kinsley
Techmotionusa.com
Techmotionusa.com
Are you a ProForm XP Exercise and Fitnes Expert? Answer questions, earn points and help others
