Question about Denon Audio Players & Recorders
Denon upa7700 amplifiers denon upa7700 the transformer out of order because the electricity i nad the plan exit power supply
3 Suggested Answers
  • 8 Answers
SOURCE: I just need to find a schematic for a Denon
Does this help?
http://www.usa.denon.com/avr3300_technotes.pdf
Posted on Dec 04, 2009
  • 55 Answers
SOURCE: Amplifier is dead. Relay in
it is in auto protect mode, something wrong with your transistor/ic
Posted on Sep 22, 2010
Completely dead NAD M15, is there an internal fuse that I can change ?
NAD M15
Problem : Dead
Possible solution : Check for Power Supply
How to Test a Transformer: 7 steps - wikiHow
If these has been done,
• Check amp power supply and low voltage regulators
These includes fuses ( many of them )
Tech Center tells you how to use a multimeter .
• There could be other electronic components but try on them first.
If the torroidal transformer is OK , then it could be a problem on the
Circuit boards.
There could be a shorted components somewhere.
Jul 29, 2012 | Audio Players & Recorders
Denon AVR 3805 will not turn on. Have tried resetting it by pressing direct / pure direct buttons but still dead
You will need to open out the set and check from the fuses. If ok check on the secondary supply, if the small transformer has failed, unless this powerrs the microprocesor the main transformer and circuit will not be powered. so use a multimeter to check this voltage to the micro-+5, if there is no supply then you will have to check on this power supply. If the supply is present then check on the mP , the crystal osc. for working. clean any dirt or moisture if present.If not there is a possiblity that this section if faulty. Check this out carefully with a voltage reading on the stages. get help if you are not competent. Hope this helps. Good day
Jun 26, 2010 | Denon Audio Players & Recorders
Nad 310 no power
The output should be 24v ac. Sounds like you have a busted transformer. Did you check out the resistor in front of the transformer.
You sound like you know what your talking about so I will not bore you with suff like glass fuses and thermal couples.
Good luck, I have had a few items like this over the years. Sometimes it's just best to send them in to the manufacture. I would look for a replacement transformer. 120v ac to 24v ac around 5 amps. Test it out and see if it works... If not, send it in.
Jan 22, 2009 | NAD C320 2-Channel Amplifier
Nad c350 no power at all
Solution if all fuses checked out OK and +/-40V are present on main PCB DC connector from power supply:
Check for +37V and -37V on small sub-power supply PCB - mounted vertically on the main power supply PCB. (next to ribbon cable connector is a layout with voltages.) If the +/-37V are missing check (replace) C501 (0.1uF) on the small power supply PCB for leakage, but also check (replace) R401 (2R2) and R402 (2R2) on the main power supply PCB. Both resistors are fuse-resistors and will have gone open circuit when C501 has gone leaky.
Aug 21, 2008 | NAD C350 2-Channel Amplifier
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
22 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
