Question about Honda Eu1000i Eu1000 Generator Service Repair Manual 61zt300
Engine runs but stalls when you put a load on it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
As the load goes up on any gas engine, the governor is supposed to open the carburater as needed to keep the engine speed up. It is normally a vertical lever with a spring attaching it to the carburater throttle linkage. Look it over and you will see it. Is it working?
Posted on Dec 19, 2013
Ive got a 110 jhonson.on land it runs great.when i put it in the water it dies when i attempt to put in gear and will not run when trying to throttle up
It sounds like you have a pieces of dirt in one of the carburetor jets. When you load the engine it can't get enough fuel to stay running and stalls out.
Sep 07, 2016 | Boating
How do I fix my mower which won't run when the deck is running - the engine keeps misfiring but runs ok when the mower is not engaged.
do a tune up misfiring is not running ok --carb needs to be cleaned rebuilt or replaced and tune up done ---or possible bad gas---when engaging blaes puts load on engine and if not running correctly will stall
Sep 07, 2015 | Garden
Why does the car stall in my 1996 s10 chevy blazer while running?
A car stalls when the engine receives a sudden massive increase in load (think when you were learning to drive - releasing the clutch too quickly would cause the car to stall by transferring too much friction too quickly from the gearbox to the engine)
If the car only stalls when you are setting out from stationary then better engine/clutch control control is needed, or there is a problem with fuel or clutch. If it is an old car, try putting more choke on when pulling away.
If the car stalls all the time, the general reason is that there is probably either a fuel or an ignition problem causing the engine to cut out. Of course, there could be any number of things wrong with your car if it stalls during normal driving
Mar 10, 2014 | 1996 Chevrolet Blazer
08 ss trailblazer stalls on take off
It can be low fuel pressure issue or clogged fuel pump.Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem :------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
Nov 27, 2012 | 2008 Chevrolet Trailblazer
I have a 2000 dodge caravan. When the engine is running with van in park engine runs fine. When put into a drive gear the engine runs really rough and even stalls. The transmission fluid is ok. When the...
Sounds like there is a problem with the Torque converter in the transmission or Transmission itself. When you put it in gear it should initially go into neutral but occasionally the transmission will stick part way in gear and partially in neutral putting a load on the motor. It is not enough of a load to get the vehicle moving but it is enough to stall the motor. This could be a simple clutch adjustment in the Automatic clutch to a PCV valve issue to a need to rebuild the whole transmission because of a problem with the control body or transmission pump itself. Sorry for the bad news.
Apr 19, 2011 | 2000 Dodge Caravan
Runs fine in park as soon as you put in reverse or drive it stalls
There are so many things that could be causing this, but I can tell you about the last vehicle that did this to me. It was the idle air control valve (IAC). Some vehicles have something named a little different, but both are for the same purpose. It basically tells the car how many rpms are running, what kind of load is on the engine, etc. It controls the air to fuel mixture in the intake, and if its off, then when you go to put it in gear, the load on the engine alone will cause it to die. It will also do this sometimes when the a/c gets turned on, or you turn the vehicle and your power steering puts load on the engine. I dont know if any of this sounds like your situation, but it was very frustrating for me. Hope this helps out some how.
Dec 31, 2009 | 1994 Ford Taurus
4wd truck stalls and will not restart til i put it in 2wd
It sounds as though your ICV is at fault. This is a idle compensation valve which is used to compensate for extra load put upon the engine while running an AC unit or a 4 wheel initiation.
Oct 04, 2009 | 2000 Dodge Dakota Quad Cab
When i put boat in gear and acelerate the moter stalls and bassicaly runs out of petrol,its a 2002 140hp suzukii have cleaned the tank n replaced the filters and its still happening?
you need to clean the carbs. your high speed jet in each carb is most likely fully or partially clogged, this is why it will idle, but when put under a load it stalls. The engine is fuel starved. I am 99.9 percent sure a good carb cleaning will fix your problems.
Jul 21, 2009 | Boating
2004 Jeep GC limited stalls ONLY in reverse
you have to be careful that it is not the safety neutral switch.since stall means different things to different people,it is hard to tell exactly what is the issue.if the safety neutral switch,which is wired to the start and ignition circuits is bad,it could kill the engine.
jack up the vehicle and look for bad or shorted wires or connectors before doing anything else.
the other thing is how it behaves with no load on it. put a floor jack under the rear differential and raise it just enough for the wheels to be off the ground a couple inches.put it into reverse with no load and see if the wheels turn in 2wd mode.
May 10, 2009 | 1994 Jeep Grand Cherokee
1993 grand am stalls when I brake quickly
Doesn't sound like an ABS problem. Seems more like a fuel or electrical problem, showing its face when you put a load on the engine, such as when you put it into Drive or Reverse
Apr 02, 2009 | 1993 Pontiac Grand Am
Honda Eu1000i Eu1000 Generator Service Repair Manual 61zt300 Logo
138 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
