Question about Toshiba 46L5200U - 46in Class 45.63 viewable LED-backlit LCD TV
46L5200U won't turn on
How do you change a backlight inverter board on a Toshiba 46L5200U TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 02, 2014 | Toshiba 46l5200u 46es 1080p/120hz Led Tv
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
I have a problem with my 46l5200u it turns on then pictures comes but theres a white lines and its like dancing too then turns to blabk screen... need help to fix this problem
Contact the authorized service centre for Toshiba. This is not a user repairable fault. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 22, 2014 | Toshiba 46l5200u 46es 1080p/120hz Led Tv
Toshiba 46l5200u turns off after red logo
Check this out....
http://www.fixya.com/support/t21733332-toshiba_46l5200u_turns_off_after_red
Nov 24, 2013 | Televison & Video
Toshiba 46L5200U turn off
Nov 24, 2013 | Toshiba 46L5200U - 46in Class 45.63...
46L5200U LED back light shuts down after about two minutes. You can see picture using a light source sound is also fine.
There should be some fault with its back-light inverter board. Either it do fail to work after some time, or it losses supply voltage after some time. You should check both these possibilities. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 23, 2013 | Toshiba 46L5200U - 46in Class 45.63...
Toshiba 46L5200U - 46in Class 45.63 viewable LED-backlit LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
