Question about Emerson LC320EM9 32 in. LCD HDTV
Only half my channels have sound - Emerson LC320EM9 32 in. LCD HDTV
Why can't I get the same volume out of channels 5/7 & 7/8 as I do from 1,2,3,4?
Those stereo channel inputs are at line level rather than instrument level.
Aug 24, 2015 | Yamaha EMX312SC Powered Mixer 300 Watt...
My clean sound is very dirty. it sounds like the crunch channel is on and turned down.
I'm not sure which amp you're playing thru. but generally the settings you want for a clean sound. check your drive (or Gain ) knob. You want it about half way.and your Channel volume, half way. those are good starts. then let your master volume do the rest. Also, make sure, if you have active pick-ups on your guitar. check the batteries. if they're low, it can cause distortion. if this doesn't resolve, then its internal. could be anything at that point.
Oct 02, 2013 | Line 6 Spider Iii 15 Modeling Guitar...
Missing Channels
you try to re program it sound like antlong is no more
all ch are dig
Sep 09, 2009 | Insignia LCDTV26 26 in. Television
Phillips 42pf9630a 42 in
A code 7 is related to a hardware problem that reqiures service.
If you want to get a referal to a Philips authorized service center call 888-744-5477 and they can prive contact info for a servicer in your area.
Aug 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
No sound on about half of the channels
Press the menu button on the remote then select #1 AUDIO once in that screen select #3 AUDIO PROCESSOR thats where you will have the selection of MONO, STEREO or SAP.
Mar 15, 2007 | GE 46GW947 46" Rear Projection Television
Emerson LC320EM9 32 in. LCD HDTV Logo
24 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
