Question about Onkyo TX-NR801 Receiver
No sound coming out to speakers. Headphones ok
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
When I plug in a headphone from the jack in the back the sound still comes out the speakers not the headpone. Element fxl-1910
Is your Headphones ok - Have you tried them on something else?
Is the plug on the headphones of the correct type and size?
If you mute the TV or turn down the volume - does this affect the headphone volume?
Also, Do you get sound out of the Headphones at the same time as the speakers?
If the above checks out to be OK - You may have a faulty Headphone socket in the TV.
Normally when you push headphones into a TV it usually pushes a piece of Metal in the head phone socket that disengages the speakers
The socket can go faulty
Jun 22, 2011 | Element Electronics FLX-1910 19 in. LCD...
The sound coming from my speakers connected to the pc sounds as though it is in a big hall.been fine for months suddenly happened,plugged headphones directly into the pc thinking it would be ok and get...
yes what happened? Headphones bypass some circuitry so that you can test if speakers are good or not. You are probably bypassing the DSP which emulates different settings.
Apr 10, 2010 | Dell Vostro 200 Desktop Computer Intel...
Audio from laptop speakers is fine, headphones are not.
Do these headphones work OK in another machine??
If not they are faulty / If so then sound port may be faulty.
'Ensure it is enabled in BIOS. press DEL key when booting and look for similar.
Mar 23, 2010 | Dell Vostro 1510 Laptop
Getting the sound on the right speaker only
Its likely a broken wire. You can take them apart if you are careful and re solder the wire if you have the tools and are ok with doing that. its a little tricky. if you need more help email me. n_raven99(at)hotmail.com
Mar 20, 2010 | Bose TriPort Consumer Headphones
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
Equium Laptop Headphones Not Working
The jack might be disconnected from the mobo,or it's simply broken or the headphones don't touch the contact metal properly
Oct 29, 2008 | Toshiba Computers & Internet
Marshall mg15cd practice amp sound ok through headphones but does not come from main speaker when h/phone lead is removed
Hi davyboy5
Sounds like the speaker has blown or maybe a wire has come off. Sometimes the headphone socket can go faulty also. Do you have nyway of testing the speaker?
regards
robotek
Jun 13, 2008 | Audio Players & Recorders
My internal speakers have sound when headphones are used but no sound when they are used without headphones
my frnd the internal speaker will have sound by default it comes from dos...When it comes for headphones or speakers u have to install the sound drivers which comes from pc.....install it it will work...
May 20, 2008 | Gateway Computers & Internet
Onkyo TX-NR801 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
