Question about Bachmann Crafts & Hobbies
Engine squell loud squel at hi speed
3 Suggested Answers
  • 59 Answers
SOURCE: Very Loud squel from vehicle..not alternator..changed belts..
check your belts. pull on them
Posted on Apr 29, 2009
perpetually
  • 360 Answers
SOURCE: 1992 Pickup: loud squelling sound under hood when started...
Sounds like a loose belt.
There are a few things that can cause a belt to slip like that.
The belt could be not tightened all the way. If it uses a sepentine belt with a tensioner, the tensioner could be bad. If it is not a serpentine belt, then you will have multiple belts and the one that is making the noise can be loose. Use something to pry it tight and tighten down the bolts holding the component th belt goes to.
It can also be a bad pulley. Pulleys have bearings inside of them, at times the bearings will go out and make the pulley hard to turn. You can usually find this easily by taking the belt off and turning the pulley with your hand. If it is hard to turn or makes a grinding noise when turned...it is bad and needs to be replaced.
Old belts can also cause this along with a belt that is wet. There is a spray on Belt Dressing that helps get rid of noisy belts, but I consider that a bandaid to a bigger problem.
Posted on May 03, 2010
When I first start motorcycle I get a loud squel. Once it starts the noise stops. I had the starter rebuilt thought sure that was it. But all back together and still squelling
Hi, Anonymous I just loaned my brand new pair of listening ears to your local dealers chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. Good luck and have nice a day.
Dec 05, 2015 | Motorcycles
Loud squeling - this is second load of dishes with this machine
Sounds like you either have a defective main pump (motor), or you may have someting caught in or around the impeller.
Dec 19, 2014 | Samsung Dishwashers
How to stop newly installed brake padc from squelling?
You can use coperpasta on the brake pad , that help for squeling.
Aug 16, 2014 | 2008 Toyota Tacoma
Squealing noise on 01 ford ranger while accelerating
Hi, I'm glad to help!
First you need to remove the drive belt and spin the Alternator, A/C Clutch and Water Pump pulley's and see if you hear the squeal. Its possibly it may have to be under a load before you hear it but its worth a try. It's also possible it could have something to o with the Throttle Body or Intake Manifold. Hope this helps and have an awesome day.
Feb 25, 2013 | Ford Ranger Cars & Trucks
The engine makes a squeling sound and the transmission keeps slipping i think it might be the transmission pump
the squelling from the engine is ur surpintine belt. my transmission was slipping in my 1998 didge avenger so i took it ot a shop and it ended up being my whole transmission. i thought it was the pump too
Sep 14, 2010 | 1998 Dodge Avenger
2001 Lincoln LS squells or squeeks when steering wheel is turned.
power steering unit probably going out !! Have you checked the fluid level in the power steering pump!!swampratt200!!AAAEEE!!!
Jul 21, 2009 | Lincoln Continental Cars & Trucks
Loud squeling noise during wash cycle
you have a weak or broken spring on the motor or the belt has stretched
Apr 09, 2009 | Washing Machines
Crafts & Hobbies Logo
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
