Question about Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh)
My yardworks snowblower engine not running
I have changed the sparkplug, new petrol, trying the electric start but not working
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 17 Answers
Need more information, several reasons why an engine won't run
Posted on Nov 27, 2013
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
How to change sparkplug in yardworks snow thrower 3754?
try this link http://needmanual.com/mtd-yardworks-603753-6-60-3754-4-snow-blower-owners-manual.html . it looks like the spark plug may be hidden under the cowling on the piston head you may have to undo some screws . look for a thick wire follow it to the spark plug.
hope this helps.
Jan 19, 2015 | Garden
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
Yardworks snowblower problem engine no starting
check out the interlock switch system, check battery with a load meter first to make sure battery is up to snuff
Nov 24, 2013 | Tecumseh Snowblower Snow Blower Starter...
We have a yardworks snowblower and when not using the wheels always lock up. how do you unlock them without turning on snowblower.
Had the same issue and found out that the wheels lock when the motor isn't running and the accelerator handle is engaged. I still had both handles tied down from transporting home and it rolled fine after they were untied. Hope that helps
Oct 21, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I have a yardworks snowblower with Tecumseh HMSK80-10 engine , it runs erratic when idling from low to high even backfires at times , i have tried gas line antifreeze , fuel stabilzier , new spark plug...
It is very possible that improper storage has left residue in your fuel system causing restriction of fuel supply. answer these questions and get a better answer. 1. Do you have to use partial choke or have to continually prime your engine to keep it running. 2. Look for physical damage to shutdown switch button or key switch wire. If this wire comes in contact with any metal surface other than its intended contact, usually near the engine. 3. Finally use an additive in your fuel system that attacks varnish such as carb and choke cleaner. In many severe cases your fuel system may need to be serviced by a professional familiar with the teardown and inspection of the fuel system. Good start though by changing your plug and fuel line antifreeze. As far as fuel stabilizers go I have been told but am still a novice when it comes to fuels that contain ethanol as I have heard that they may not have a very long shelf life. A few tips from an old ag. tech. Gods Speed to you! P.S. If this is a 2 cycle engine their are other things to consider.
Mar 01, 2011 | Yard Machines Garden
My yardworks snowblower is running irradic. The muffler cap became red hot and spitty noises from the engine. Up/ down over and over with the engine noise? What to do?
It sounds like the muffler may be plugged up with carbon. When the muffler is cool carefully remove it and visually inspect the inlet port, and outlet on it for black carbon build up. Also check the exhaust passage in the engine block. If excessive build up is present try to chip it away with a screwdriver or the like. Reassemble and see if that helps.
Feb 04, 2011 | Garden
Kazuma Panda 110 Quad - Starting problem
have you tried a new spark plug???? try new sparkplug there may be a spark on the old one but it may not be strong enought, if that dont work you know its petrol problem!
Nov 22, 2009 | Quad Cycling
Diesel auto to petrol manual
I think that you can buy another car for what it would take to do that conversion.
Lets' see off the top of my head.
carburator
manifold
new heads to accept spark plugs?
new body control module
new engine control module
then keep in mind that even with all the above it still might not work because you may need proprietary parts only made for a gas engine, and you have a diesel. An engine swap may be doable but I ahve never heard of it working out in the end.
Oct 01, 2009 | 1991 Nissan 240SX
Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh) Logo
271 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
