Question about Cambridge Soundworks CD-740 Clock Radio
Cd stuck in machine - Cambridge Soundworks CD-740 Clock Radio
How do I get a stuck CD out of this machine?
You may have to remove the receiver from the vehicle and disassemble it to get access to the stuck CD for removal.
Apr 27, 2015 | Car Audio & Video
Cd stuck in e machine?
to open CD tray you need needle (or some hard wire like needle) and put it to small round pinhole near CD tray button and you get tray open and can remove CD disk.
Nov 15, 2012 | E-Machines Computers & Internet
Cd player doesn't work
Try loading an old CD under the "stuck" CD...this may take several attempts. Also you can go online using "stuck CD" and get several helpful tips...Hope this helps.
Dec 13, 2011 | 2008 Mercury Sable
Emachine cd tray stuck closed
Hi beverlylu328,
It seems like your cd tray has already a defective mechanism.
If a cd was stuck in your cdrom, use the safety eject pin included in the cdrom package.
You can use this even your PC is turned off.
I strongly suggest to replace your cdrom with new one.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 31, 2011 | E-Machines emachines (emachinees) CD-ROM...
CD drive button broken
You might try to remove front cover from you CDROm and checked whether button is not broken or stucked
Oct 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
SEA2300 +ESP - cd disc stuck in player
disconnect the power and open the side where the cd motor is and remove manually
Jun 20, 2009 | Sea Worthy 9001G Marine Casseiver...
Macbook cdrom stuck in copy mode
hold down power button until your machine shuts off. then power back on. you should be fine. if the cd is stuck in the drive, restart the machine and hold down the mouse button while restarting - the cd should eject itself.
Sep 02, 2008 | Apple MacBook PC Notebook
New (to me) blueberry cd stuck in drive
If this is a slot loading machine there may be a little hole next to the CD-Rom drive. Slide a paper clip into the hole and the CD should pop right out. If this is not a slot loading machine then it will be the same procedure only the hole for the CD-Rom will be on the CD-Rom tray itself
Aug 07, 2008 | Apple iMac Blueberry Mac Desktop
CD tray stuck
Problem is very simple, Switch off system, unplug from mains. Open the Cover panel, and remoove CD. Close machine. Plug into mains. Open Tray, put in anothrer CD, enjoy your music.
Mar 05, 2007 | JBL Harmony Shelf System
Cambridge Soundworks CD-740 Clock Radio Logo
64 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
