Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Where is the water valve located - LG LFX25971ST Bottom Freezer French Door Refrigerator
    Top Expert:
  • LG Master
  • 12,962 Answers
Usually by the bottom of unit.. Follow the water tubing going into unit and presto........there it is!!!!!
Posted on Nov 28, 2013
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
When the dishwasher goes into wash mode there doesn,t seem to be enough water in the unit to spray out the arms. when i pour water into unit it works ok until its next cycle?
Hello, If your unit is not getting enough water inside of it one of the first things that you would check would be the water inlet valve. If you follow the water line going to the dishwasher the water line itself connects to the inlet valve. Using a multimeter you can remove the connection going to the solenoid to assure that the valve is getting power if the valve were not to be getting power then you would look at the float switch which is usually found to the right of the inlet water valve. If you do have power going to the valve yet you still do not have water flowing past the valve you will most likely need to replace the inlet water valve in the unit. If you have any further questions or you have a problem locating the inlet water valve message me back your make and model number of your unit and I will try to locate your schematic to show the location of the valve. Also if you do have any questions message me back those as well. Thanks again I await your reply Rick
Aug 31, 2011 | Siemens Dishwashers
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
Water dispenser leaking.
The inlet valve will be located in the back of the ref. You have to remove the access panel and the valve will be mounted usually on the right hand side (if your looking at it from the back). To replace the valve you have to shut off the water at the saddle valve probably located in the basement. If you are replacing the valve then I would also replace the saddle valve at the same time its only about 10 bucks, because they usually gunk up w/ calcium deposits which lead to problems with the inlet valve of the ref.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Refrigerators
Water doesn't input
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve....
Sep 06, 2009 | GE Dishwashers
Water inlet valve - where is it located - model RCA MSX27D
The water inlet valve is located near the bottom in the "back" usually on the side the icemaker is located. On certain style freezers (boats, etc.) the inlet valve may be located at the bottom in "front" on the icemaker side.
Aug 11, 2009 | Freezers
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher wont take water
Jun 12, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
My dishwasher sounds like its working but when i open it nothing
1. No water
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
May 30, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Dishwasher tub will not fill with water
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
May 24, 2009 | Dishwashers
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
