Question about Watches
Need battery for Roots Ry2202 - Watches
How do I set time on roots r316
Have a jeweler do it. Or look for a manual on Google.
Dec 25, 2014 | ROOTS Watches
How do i set my digital watch,roots ry2129
Here is an actual 'live' web link (I just checked) - to Roots, "watches":
http://usa.roots.com/on/demandware.store/Sites-RootsUS-Site/default/Search-Show?q=watches&simplesearch=
If nothing else, if you scroll to the bottom their contact info appears which I am also pasting below. Good luck to you!
Contact Us:
• 1-800-208-0521
• Outside of Canada: 1-972-265-4120
• Email: onlineservice@roots.com
Nov 09, 2014 | Watches
How to set time on roots squadron ry2168
1- Press and hold RESET and LIGHT together, be patient
2- With ST/STP change the digit blinking
3- With MODE choose hr, min, date....
4- Once done press RESET.
NOTE: To set T2, display T2 before doing the above steps.
Mar 09, 2014 | Watches
Roots athetic ry2203
Hold the mode button, until the times start flashing, you might do this wrong and activate stopwatch. Then you press mode again and it will show the time you want to change. Press the start/stop button to toggle through seconds, minutes and hours. And months and days
Oct 26, 2013 | Watches
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
How do I set the date on my Roots MAI TAI RY2142 Watch for Women?
Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now, now press and release the mode button and enter the time setting mode, the seconds will be flashing. Now press and release the start/stop button (top right) and the minutes will flash, again for hours, again for the month, and again for the date. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. Worked for me, hope it does for you too. Most of the other setting changes are tricky as well, just ask for help again if you want to change the alarm or 12 or 24 hour clock etc....
Jan 03, 2013 | ROOTS MAI TAI Ry2142BLK Watch
How do you set the time on the Roots Womens's Mai
Feb 05, 2010 | Watches
My watch didnt change for daylight saving time
how to set the time on a roots RY2122 watch?
Please HELP!!!!!!!!!
Nov 01, 2009 | Casio Wave Ceptor Watch WVA105
Install back on a roots steel watch
Hi, my husband just fixed mine; it was tricky but he got the back put back on. He lined up the back; it has a small **** - to the front part where you set the time ; then he had to bang on the back of the watch a bit on the edge that is sticking up and won't go in (hope it makes sense?) and finally it did clink into place. He used the handle of a knife~ not the safest way to do it with but he was determined to get it back on and couldn't believe what a hassle it was to change a watch bettery~.
Hope this helps you out.
Aug 18, 2009 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
