Question about CDA CI392 Front Load Washer
Cda c1931 washer dryer stopped
SOunded like something inside snapped at start of wash cycle then it stopped. Have unplugged/press cancel twice, keeps doing it
2 Suggested Answers
  • 129 Answers
SOURCE: How to work dryer
vent hose is blocked
Posted on Feb 02, 2010
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
    For the Elite (HE) machines:
    Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
    Other Kemore electronic washers:
    Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
    Good luck from Detroit, MI.
    Jun 12, 2011 | Kenmore Washing Machines
    Flashing f code
    Hi, "F" Variables (F4 to F16) (Electrical Problem) Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
    Oct 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
    according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
    Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
    Keep getting error f20
    Press the Pause/Cancel button twice to clear the display and cancel the cycle. Unplug the machine and remove the fill hoses from the water inlet valves. Check the inlet screens for clogging and clean it. Make sure that the water supply valves are open and water is present. Check the drain hose for siphoning.
    Press and hold the Start button to start a new wash cycle. If the error code flashes again, verify if there is water present inside the tub. Check the water inlet valve if no water is present. Check the pressure switch if water is present.
    Feb 05, 2010 | Kenmore HE2 Plus Front Load Washer
    I hit cancel in the middle of a cycle and now it keeps saying F1
    From the maytag website:
    To remove the error display, press Power/Cancel or Pause/Cancel twice.
    If Power/Cancel or Pause/Cancel does not work:
    Unplug washer or disconnect power for one minute.
    Plug in washer or reconnect power.
    Re-select the cycle and press Start/Pause.
    NOTE: If the error remains on the display, call for service.
    Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
    Kenmore Elite He3t front load washer - error code reads H & F
    the F code is a puwer outige. This is how to fix
    for service.
    This is what an HF code is.
    "FH" (Water Inlet Problem--no water or insufficient water
    supply)
    Select PAUSE/CANCEL twice to cancel the cycle. Unplug
    washer or disconnect power.
    Check the following:
    Are water faucets completely turned on?
    Are screens at inlet hose connection to washer clogged?
    Are water inlet hoses kinked?
    Are water inlet hoses frozen?
    Plug in washer or reconnect power. Re-select cycle and press
    Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
    I need to cancel a washing cycle in the middle of the cycle.
    usually pressing PAUSE/CANCEL twice cancels the cycle and shuts it off allowing you to then re-start the cycle. If not try unplugging it and see if it resets to allow you to start cycle again.
    Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
    14 cycle front load washer fridgidaire
    press cancel. (turns off washer)
    press start/pause (wake up)
    hold cancel and start/pause 10sec
    last error code will come up.
    E47 door lock error
    check wires connections to the door lock..
    replace door lock..
    hope it helps
    Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
    F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, then call for service
    Jul 18, 2008 | Whirlpool Washing Machines
    CDA CI392 Front Load Washer Logo
    Top CDA Washing Machines Experts
    NOEL
    NOEL
    ray gallant
    Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
