Question about Photogenic Wired Remote Digital Flash Power Display Unit for the PowerLight 1250 Monolight. PLDD-1
Photogenic 1250dr will not flash
Has power but will not fire
How do I use this flash as a slave?
You need to set the flash to slave and the same channel as the master. If the flash doesn't have this function it may be able to be fired optically. Set the master flash to low power and set the off camera flash to optical.
Jul 15, 2015 | Sunpak DigiFlash 3000 External Flash
How many kind of manual flash making vivitar company slr camera
As far as I know, every Vivitar flash can be made to fire in manual full power mode. No exceptions. Even the modern full dedicated E-TTL units can fire manual full and fractional power levels.
Sep 10, 2014 | Vivitar 285HV Flash
What is the difference between the flash and continuous lighting, why not using continuous lighting for photography?
Two main reasons flash is used over continuous lighting.
Power. Lighting a scene for minutes uses much more power than lighting it for a fraction of a second. You may have noticed that most continuous lights need to be plugged in to a power supply, while most flash units work with small batteries. It may not make much difference if you're shooting indoors in a studio, but if you're out in the field and have to move around, it can get difficult lugging all that gear around.
Duration. A flash unit provides a very brief flash of light while a continuous unit is, well, continuous. A flash can freeze action much better than just using the camera's shutter. Try it yourself sometime: turn on the lights in the bathroom (and/or bring in your continuous light units) and take some pictures of a dripping faucet. Now turn off the lights and take some flash pictures of the same thing. See the difference?
Dec 17, 2013 | Photogenic DigiLight Continuous 500 watt...
My quantum flash is misfiring...fire a few shots, then misfire again.
I can repair it for you or try this first.
Turn power on with no camera connection.
Does it fire by itself?
PC Sync on camera, does flash fires by itself?
Dec 14, 2012 | Quantum Qflash® 5d TTL Flash
I cannot seem to get the flash to fire consecutively ,I have changed the batteries for lithium, and yet still one shot to the next shot is at least 7- 10 seconds before the flash will fire again. what to...
Hi windnenergy, It is the recycle of the batteries and, power setting of the flash. Lower power settings will allow us to shoot faster. So, check the power settings, run tests to see how long the flash recycles at lower power settings. You may find you do not need a full flash power shot.
Dec 05, 2010 | Cameras
QFlash does not fire
You have a defective PC Cable.
Try this:
Turn on flash and wait until ready.
With PC cable connected to flash only.
Short out center pin to outside of PC Cable, this should fire the flash.
a.l9609@gmail.com
Jun 11, 2009 | Quantum Q Flash T5dR Digital Flash Head...
Sekonic L-358 light meter will not trigger my photogenic lights anymore? Thanks, Liz
Hi Liz
have you checked your sync cable?
tried meter on another system (for comparison)?
Depends where you are.. Mamiya in the USA can solve the problem.
Jun 08, 2009 | Sekonic L-358 Flash Master Light Meter
Exposure problem
Your 40D requires that you use an ETTL-II type flash like the Canon 380-EX. What flash are you using?
Mar 25, 2008 | Canon EOS 40D Digital Camera
Metz 45 CL-4 flash problem...
Will it do the same in Manual Modes?
Use DVM and measures voltages from Hot to ground. What is the voltage?
atdlee@netzero.com
Feb 07, 2008 | Metz mecablitz 45 CL-4 TTL Flash
Photogenic Wired Remote Digital Flash Power Display Unit for the PowerLight 1250 Monolight. PLDD-1 Logo
Top Photogenic Cameras Experts
Tom Chichester
Doberman
Are you a Photogenic Camera Expert? Answer questions, earn points and help others
