Question about Sharper Image Dyson Slim DC18 All Floors Vacuum
My dyson runs for a few seconds then starts slowing down to off. It is fully charged
When I hold the button in on my dyson it runs for a few seconds then starts slowing down and turns off.It is fully chsrged.
My Dyson V7 vacuum has just recently started working but with an intermittent suction only, not running consistently.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner running intermittently. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 18, 2017 | Dyson Vacuums
My v6 is stopping and starting in pulses but it seems to be fully charhed
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jan 07, 2017 | Dyson Vacuums
My Dyson v6 is just a few months old, has started "pulsing" even though fully charged.
Ava B.
Jan 02, 2017 | Dyson Vacuums
Dyson v6 surges on and off
There are a number of things you need to do that may solve the issue you're having with your vacuum. First, make sure that your battery is charging and working. Second, check the MAX button. If the MAX button lights up and flashes when your Dyson cordless vacuum keeps pulsating on and off, hold the power button and depress the MAX button to turn off that function. You may have to try a few times to get the hang of it. And lastly, look for any blockages in attachments because the pulsating is caused by a lack of airflow as the motor is protecting itself by pulsating and then ultimately cutting out.
You can check this video tutorial which will teach you on how you may fix it:
Ava B.
Sep 18, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
My Dyson DC35 stalls. I've thoughly clean it, so it's not a clog problem
1st make sure battery is fully charged.
Next, wash the filter, just follow the instructions in the manual.
If the filter is clogged the motor will try to run but then cut out to protect the motor from damage.
Mar 30, 2015 | Dyson DC35 Handheld Vacuum
When I try to use my Dyson DC59 it won't start and blue lights on both sides of the battery start blinking. What does this mean?
Hi there, it's Jack at Dyson.
From what you've described, it sounds as if you may be using your DC59 set to Boost mode. This will provide 6 minutes of highest suction for really stubborn dirt, but for regular vacuuming normal mode should work effectively.
To switch back to normal mode, ensure your machine is fully charged (this will take a maximum of 3.5 hours), then hold down the on/off trigger, and at the same time, press the illuminated Boost button on the rear of the machine.
You might also find our Getting started guide useful:
I'm confident this will resolve the issue, but if you would like some further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 13, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
My Dyson DC31 runs for a few seconds then cuts out and won't work at all. It is fully charged. We bought it just over 2 years ago and it has worked perfectly until now. It is clean and has no apparent...
Hi Jean, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC31. If it cuts out in use when it's fully charged, we'd need to take you through some quick diagnostic checks when you have the machine at hand. This will help our experts determine what may be causing the issue.
Please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 04, 2013 | Dyson DC31 Animal Bagless Handheld...
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
http://www.dyson.com
Apr 07, 2013 | Dyson DC31 Animal Bagless Handheld...
My DC 16 will only run for a second each trigger pull. The battery is fully charged, it has plenty of suction, just wont run for more than a second. I cleaned the filters.
I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 25, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Sharper Image Dyson Slim DC18 All Floors Vacuum Logo
20 people viewed this question
Top Sharper Image Vacuums Experts
JoeVacs
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
