Question about Samsung Refrigerators
Where is the water pump located?
Trying to clean out the water lines due to bacteria in them. We turned off the water but where is the water pump located?
    New Friend:
  • 16 Answers
Its most likely just the pressure of your water supply
Posted on Nov 25, 2013
Bacteria in water lines
Water comes straight from your supply via a clear hose then through a filter that should stop all bacteria & germs, I would check that first, might need changing.
Nov 24, 2013 | Samsung Refrigerators
Tip
IRobot Mirra 530 Tips & Tricks
Tips from iRobot Resources:
Run Mirra only when in the water.
Mirra has a very strong motor system that needs to stay cool for optimal performance and life. Your pool water around the motor helps keep it cool during operation. Therefore Mirra should not be run outside of the pool due to the risk of overheating the motor.
Choose the correct filter canister.
Use the Large Debris Filter Canisters when the pool contains a significant amount of large debris (leaves, insects, etc.) and when the pool is opened for the season or cleaning during the Fall. The Fine Filter Canisters are ideal for filtering small debris such as algae, sand, silt and bacteria and for regular pool cleaning maintenance during the peak of your pool season.
Keep Mirra working at peak performance.
Mirra uses the powerful force of water pumped through its filter to clean and circulate pool water and to propel itself around your pool. It pumps and filters more than a gallon of water every second! Clean the filter canisters regularly by removing them from Mirra, emptying its contents and hosing it out. Keeping the filter canisters clean will ensure optimal cleaning results and strong pump suction.
Allow the motor to cool before removing the robot from the pool.
Mirra's power supply has an automatic timer that shuts Mirra off after each cleaning cycle. Wait 20 minutes before removing Mirra from the pool to allow the pump motor to cool. Turn the power supply off and unplug it from the electrical outlet before removing Mirra from the pool.
on Sep 17, 2013 | iRobot Mirra 530
Tip
How to clean dog toys
Different types of dog toys require different cleaning due to their materials and the type of germs that they attract.
Plastic and rubber toys- these are the easiest type of dog toys to clean. They can be either hand washed with soap and water or in the dishwasher. If you do choose to clean them in the dishwasher, make sure it is without a detergent.
Rope toys- these toys attract lots of bacteria. In order to clean them, it is advised to put them in a microwave for a full minute. Another way to clean them is just like with plastic and rubber toys, to put them in a dishwasher without a detergent. These two methods will kill the bacteria.
Stuffed animals- these toys attract lots of bacteria as well. In order to clean them, put them in the washing machine. In most cases, they will come out fresh and clean. If the stuffed animal is made poorly, then it will not survive the washing machine.
on Aug 26, 2012 | Dogs
Oil type substance is streaking down the side of the tub and apperars to be coming out of the jets any ideas how to fix it
This sounds like bacteria coming from the water lines. When was the last time you ran a cleaner through the jets?
You should run a good Jet Clean type product of Maintenance Product in order to prevent the build up of bacteria in the water lines when the bath tub is not in use.
RodUS Parts Center888-521-6183
Feb 22, 2013 | Home
My mazda 6 v6 2004 smell oil when starting ventilation
The smell is typical of older Mazda aircon.
Purchase an aircon cleaning spray which is discharged into the aircon system by selecting recirc , cloing the windows for 5 minutes . This cleanses the system which is probably contaminated with bacteria.
Recharging your air con will help as well. The smell is due to evaporate condensed water mixed with sludge and bacteria .
Sep 20, 2011 | 2004 Mazda 6
We use our jacuzzi once every two weeks. Every time we get small black particles of debris of some sort that sticks to the side of the tub. What is the problem?
the problem is bacteria building up in the water lines once the water dries. You should be using a jet cleaning product to clean the water lines out before they dry.
We have several different good cleaners on our site that all work well at keeping bacteria out of your water lines.
You can click on the link below and it will show you what is available.
Jet cleaners
Feb 16, 2011 | Jacuzzi Home
Where is the fuel pump and fuel filter at
The fuel pump and strainer are located inside the fuel tank.
There are three possible locations for this component due to different production dates/locations: under hood, passenger side, rear engine area, below firewall, mounted in fuel line or under vehicle, passenger side, below seating area, mounted on frame in fuel line or under vehicle, driver side, below rear seating area, mounted on frame in fuel line
Easiest method to find, follow the fuel pump lines from the tank forward, you'll find the filter.
If you change the filter, it's not a bad idea to put a little Gumout fuel injector cleaner directly into that new filter, about 1/2 full before reinstalling, that will give your injectors a quick clean. It can cause a short sputter or two but I've never seen it cause a problem and it does help clean the fuel system quickly.
You'll also want to remember to turn the key on for 3 seconds, off for 3 seconds, alternating until the fuel pressure builds before trying to start the vehicle, after repairs are made to either the pump or the filter.
Use caution when removing lines, pressure and flammable !
Good Luck
Mar 10, 2010 | 1992 Buick LeSabre
CLEANING WATER LINE?
replace the cartridge but when you do put a cap full of bleach in the filter housing .run the water for a while and this should clean any bacteria that you think might be in the line from the filter to the dispenser, be sure to run the water through the dispenser and dispell all the bleach
Oct 10, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
1994 Kenmore 90 series washer smells musty
If you do not use a hot water cycle every so often it can contribute to the build up of mold or mildew inside the washer drain lines, pump and tub.. This is a common problem for those that only use cold water cycles. The detergent alone sometimes is not enough to kill bacteria. You also need the heat from hot water. I would recommend that you run a cleaning cycle on the hottest setting you have about once per week as a preventive measure. Add some bleach to the water to kill any existing bacteria. NOTE: This may take a couple of wash loads before you notice a difference. If you wish to conserve by not wasting water and energy by running an empty wash tub every week, switch to washing your whites in hot water with a little bleach to keep them brighter. This will kill bacteria in the washer in the process. I hope this helps you.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Refrigerators Logo
42 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
