Jvc vm 35d30es - Televison & Video
How to connect a jvc model vm-35d30es to horizon mediabox
If there is only a HDMI interface it is not possible, as the TV doesn't have a HDMI interface. but there are AV to HDMI converter boxes and cables if you really want to connect.
Feb 21, 2016 | Computers & Internet
Can jvc vm-42wx84 be used as a monitor without tuner
This is a screen with a media box. The box has two connections to the display panel. The first looks like a DVI connector. The second is the proprietory control port connection. This is how the set receives commands about brightness, contrast etc, scaling, aspect ratio. It might even control such basics as power on/off.
You could try the panel just with a DVI connection, but you will have to make sure that all sources are scaled to the panel's native resolution (1024x768) before they reach the screen. This is part of what the media box does. You might be okay if you're driving the panel direct from a PC graphics card. But if you want to run it with a variety of different sources then you really need to use the JVC media box.
I can't say if the Hitachi media box would work.
Sep 10, 2014 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC vm-42wv74 television with horizontal fuzzy or black bar
Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | JVC 42 in. LCD TV
JVC PD-35D30ES Vertical lines - problem
Hello
Check its power supply board for any damaged capacitors. Replace them if found or suspected. Take special care to main filter capacitors. check all the output voltage smoothing capaciotrs too.
If all are OK, and still the problem perists, replace the power supply board as card basis.
Feb 07, 2012 | JVC PD-42WV74 42 in. Plasma EDTV
Our 42" JVC plasma now has a black line right in the middle of the screen with some colored bard similar to performing a "defrag" on a PC. Is our set "shot?" it's only around 6-years old. Model # VM-42WV74...
I had the same problem with a JVC VM-42X795. The repair man said a wire in the monitor is probably borken that provides power for that enire row. I stared with one bad row, but ow I have two.
Sep 26, 2009 | JVC Televison & Video
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at FAIR1968LANE@aol.com and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
Feb 01, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
No image at all...
The JVC C-Format camera can have one of two seperate problems that cause this symptom. The connector to the CCD comes loose and causes loss of video. Also, the CCD has been a source of problems for some time now, JVC will repair this for you free of charge if it's the CCD causing the problem. Good luck to you. Joe Weibel customelectronics.org
Feb 18, 2007 | Quasar VM-L153 VHS-C Camcorder
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
