Question about Audiovox New Original FPE2607 Remote Control
Tv changes input from hdmi 1 to hdmi 2 without touching remote.
    Top Expert:
  • Audiovox Master
  • 12,223 Answers
Open the r.control and clean the keypads from dirty, oxide, corrosion, with contacts cleaner or alcohol isopropyl.tight the springs contacts batteries with plier and then try again.
God bless you
Posted on Nov 25, 2013
47" lg 3D tv won't change inputs and only displays "HDMI 3"
Try changing inputs using the touch buttons on the front lower right bezel of the tv.
Feb 12, 2017 | LG Televison & Video
I touched the wrong button on the remote and know tv says no signal and I can't get it back
Try going to your input button on your remote and see if you are still on the right input like if your tv is using a hdmi cable from your cable or satellite box then your input should be hdmi or hdmi 1 or hdmi 2 etc... also if you have cable or satellite make sure you didn't change the actual tv off of channel 3 or 4 whichever you have your cable or satellite box set on. I hope this helps.
Feb 06, 2016 | Televison & Video
I would like help with setting up....I have the cable from the digital cable box going into the TV and still saying that is not receiving a signal
Without more details it's hard to answer this, but here goes...You should have a button on your remote that says "input" or "Source". Use your remote to check what the input is set to. Change the input and see if your signal comes in. There will be several choices. If you have a digital box it has an HDMI port, so does your TV. Normally the cable box HDMI goes into HDMI 1, or 2 on your TV. The cable just screwed into the cable inlet o the TV will be something like "AV" or "AV1" Ideally, you want to run one HDMI cable from the box to the TV. It carries sound, high def video etc; It's the only cable you need. let me know if any of this helps.
May 03, 2015 | Televison & Video
How do I connect my LG HR836T into my LG TV & LG sound system HB806 already connected
It all depends on how many HDMI input you have in the back of the TV, usually most models have 3. If you already have the TV and the sound already connected, then all you need to do is connect the player to the back of the TV to any of the HDMI input. Those are usually mark as HDMI 1 HDMI 2 and HDMI 3, so when you use your remote control to change the input in the TV, make sure to which input you connect the player to. You don't have to touch or do anything to the sound system.
Feb 15, 2015 | LG Audio Players & Recorders
Www roku com link
This sounds like a basic setup, so correct me if I made any wrong assumptions.
You have 2 "output" devices: a Roku and a cable box. Both have HDMI outputs.
You have 1 "input" device (your TV) that has 2 HDMI inputs available.
So, you need one HDMI cable to connect your cable box to your TV. Remember what HDMI port it's connected to - the back of your TV probably says "HDMI 1" and "HDMI 2" or similar. That's the "input name" of your TV.
Connect your Roku to your TV with another HDMI cable.
Now turn on your TV and use the remote to change between the inputs. Most remotes have a button that says INPUT or SOURCE (or sometimes a dumb little icon with no writing). If you press that it should change inputs. Usually, each time you push the button will cycle to the next input, so sometimes you have to hit it a bunch of times until the on screen menu shows the input you want. Most TVs will automatically switch to the selected input after a few seconds, so you don't have to push any buttons on the remote to tell the TV to change inputs.
If "at the same time", you meant actually watching both Roku movies and your cable at the same time, you are talking about a TV feature usually called "picture in picture". That should be possible, but will depend very much on your TV. I'd suggest checking your TV manual, or calling the company's 1-800 number and asking them to talk you through it.
Jan 07, 2014 | Computers & Internet
How to connect to HDMI
newer tvs need to know that HDMI is attached to give you signal also need to turn on device from where HDMI signal comes from.post the model of your tv ,or if universal remote has input try this,1.- connect hdmi ,2.- turn on device(dvd,ps3,blue ray, etc.) 3.- press input on remote ,or go to menu manually on tv and find input.hope it works.
Dec 14, 2013 | Televison & Video
I have problems having the Logitech One to choose right input on my SonyKDL-32EX501. It changes between HDMI 1, Analog and AV1, and ignores other active ports. Have to use Help every time in order to...
If HELP fixes the problem, then this is a delay issue. Try increasing your TV's input and inter-device delays.
1. Click 'Settings' next to the icong for your TV in the software.
2. Select 'Adjust the delays (speed settings)'
Apr 26, 2010 | Logitech Harmony One Advanced Universal...
Change HD settings on lg plasma tv without remote
u need tv remote, with that u can go to the options for ur tv and enable the hdmi allowing ur ps3 to come onto ur tv.
Dec 31, 2008 | LG 50PX1D 50 in. Plasma Television
Audiovox New Original FPE2607 Remote Control Logo
24 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
