Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer will not go below 30 - Frigidaire FRS3R5EMB Side by Side Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Hello Paul, I am happy to assist you!
If your freezer is not cooling below 30 degrees, it could have a floating restriction in the lines or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working correcting, the evaporator fan not turning, or even coolant in the lines with incorrect levels to properly cool. Do you hear the compressor running? If the compressor is running, humming or even a little warm then that is typically normal. However, I suggest cleaning your freezer out completely including the coils you can reach (typically located underneath or behind the unit). Also try checking and see if the door seal is bad; place a dollar bill between the body of your freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bills falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, it would be advisable to connect with a professional to accurately pinpoint any potentially more serious issues.
Posted on Nov 26, 2013
  • Electrolux
    Electrolux Nov 26, 2013
    Hello Michael! I hope this information helps to some degree.
Freezer gets to cold
HI
If your thermostat cannot control your motor automatically for on and off then you should change it as it is the only unit that can cause this problem.
Feb 13, 2014 | Frigidaire Freezers
Refrigerator FGHX2644KF2, THE FREEZER IS NOT COOLING OFF. I HAD A SMALL CHILD TURN OFF THE FREEZER AT THE CONTROLS, BUT DID NOT CATCH IT FOR ABOUT AN 30 MINUTES, when I turned it back on the temp said...
is it staying at 16?? a freezer thats attached to a refrigerator would be considered fully functional about id say 30 degrees and below, As long as it stays under 32 I wouldnt worry about it, you can always try unplugging it for a few minutes if you want, but as long as temp stays at 16 or lower than 32, its fine............. a deep freezer are the ones that usually get alot colder than 32, but generally only because thats the systems only job, its not also running a refrigerator.
Nov 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
Continental Freezer model F2 404A refrigerant not cooling properly. Replaced cap tube, and filter drier, evacuated, and charged. Box temp not going below 32' and ice forming at beginning of evaporator....
Check the compressor efficiency. See if it will pump down. In most cases, a good compressor will pull down to about 15" vacuum. Also, be sure that the refrigerant amount was weighed in and not done by pressures only.
May 18, 2017 | Continental Freezer Wide...
What is the coldest recommended temperature a chest freezer can withstand in an unheated garage?
Hi there
It should have no problems down to -30 deg C or -20f
But it may sweat on the outside if it is damp and cold, which can cause corrosion of the casing.
Below the above temperatures the thermostat will not operate
Regards
Gordon
Apr 17, 2011 | Freezers
Gbs20hbsww bottom freezer the freezer gos below 0 but the upper refrigerator stays at 60 I replaced the evaporator fan motor but it will only make 1/4" turns the damper door makes a clicking...
check the damper control on the freezer the refrigerator section gets it's cold air from the freezer sometimes the air damper needs adjusting or replaced
Nov 17, 2010 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
Automatic defrost has stopped working. How do I fix it?
Good day,
There are 3 components to a defrost system. The defrost heater, which is mounted to the bottom of the cooling cool, behind the rear panel in the freezer compartment. Second, is a defrost thermostat, which is a 1" round disk clipped to the top of the same coil in the freezer compartment as well.
They both can be checked with an ohm meter but the coil must still be cold. Unplug the machine.
The heater should check at below 30 ohms. If it tests infinity (no resistance) it is defective and needs replaced. The defrost thermostat (which must be below 30 degrees for testing) should read zero ohms. If not, replace. It is the most common part to fail.
The last component is the defrost control, which is mounted in the fresh food compartment and can be either a standard timer or adaptive (solid state) control. It is the second most likely component to fail.
Below is an excellent tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Apr 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
REFRIGERATOR WARM ABOVE 60 FREEZER 0
Try moving the air flow setting in the refrigerator up higher. I know my beer wasn't that cold before and moved the setting from 2 -6 and that made all the difference
Jan 02, 2009 | Refrigerators
Traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Nov 23, 2008 | Freezers
FREEZER WORKS GREAT BUT FRIDGE NOT SO GOOD-COILS CLEAN
Sounds like a evaporator fan or defrost problem. Your freezer should be colder then that, 5 degrees or below. Anyway, any cold air the fresh food compartment gets is blown over from the freezer, verify you can feel the air flow or visually see or hear the fan in the freezer compartment. If that checks ok more then likely your defrost system has a defect. This consists of a defrost timer or adaptive defrost board, a defrost terminator which is just a bi-metal thermostat set typically at 30 degrees or so and a heater element, either a calrod or 1 or 2 glass encased elements. When this system fails you end up with a block of ice on the coils through which air cannot circulate.
Oct 21, 2008 | Whirlpool Refrigerators
Refrigerator will not cool
Do you mean the display won't go below 70 or that the actual temps won't go below 70? First try to unplug the refer for 20-30 seconds then plug it back in. Hopefully that will reset the levels to factory settings (usually around 0 for freezer and 36 for refer).
Dec 18, 2006 | Kenmore 73503 Stainless Steel Bottom...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
