Question about Video Game Consoles & Games
I have hama v18 and the throttle isn't as steady as it shoudl...it sheems to not give full power right away and after a while it loses full power again and so on...any help?
It worked the first couple of days but then it suddenly appeared to have throttle issues
  • 21 Answers
SOURCE: 1992 buick lesabre starts fine.
You check the coils with a ohm meter. They should 6-8 thousand ohms at the spark plug connections. One lead to one spark plug connection and the other lead to the other . It's not likely a coil for stalling. If coil , Your car can still run on four cylinders. It can be a ignition module. It fails when it gets extremely hot. The module is located under the coils.
Posted on Jul 19, 2008
mediarich
  • 188 Answers
SOURCE: laptop sudden poweroff randomly
I googled "fujitsu laptop forum" and read a couple of posts and it may be an AC input jack problem. If the computer does this without the battery and only AC plugged in then you could assume it's not the battery or charging circiuts. Some laptops get mother board problems but that was not what I read. It wouldn't hurt to go to http://forum.notebookreview.com/forumdisplay.php?f=7 and post your problem. good luck.
Posted on Sep 25, 2008
  • 1019 Answers
SOURCE: no beep no display
If you have had an electrical power surge.
It,s for sure that you have caused damage to the Motherboard-CPU And possibly The RAM ( Memory ) There is no fix for this. I,d suggest New Power Supply Unit. New Motherboard. You can then Try The Memory And CPU On The New Board/PSU.
You may be lucky And the memory and CPU May have survived.
It seems as if the motherboard has suffered the damage.
I,d also suggest investing in a surge protector also, once bitten twice shy.
Mike @ compurepair.
Posted on Dec 16, 2008
  • 6 Answers
SOURCE: My kohler driven hobart champ 10000 runs but only provides power
replace your berrings in the drive its probly as the rpms rise the centrifical force pushes the brushes against the wall causing it to short
Posted on May 21, 2009
  • 179 Answers
SOURCE: Engine sputtering
I would change your fuel filter, if that doesn't do it check your fuel pressure with a gauge at your schrader this is a pretty simple test if you are not getting enough pressure, then test your fuel pressure regulator, if it's bad replace it. if it's good got to your fuel pump, I am assuming you don't have or even know what a DSO is, so if you traced it to a fuel pump, take it to an auto technican and ask them to do a fuel current ramping test and this will tell you your fuel pump rpm's most of todays properly operating fuel pumps spin from at least 4000 rpm to 6500 rpm. happy motoring!
Posted on Jun 01, 2009
Model 324L-x. Why does it lose power at full throttle?
Adjustment on the H needle is needed...
If the unit ever bogs on full throttle , or seems to struggle then you have to adjust the High.
You do this by holding down the throttle as you turn the needle. If you have the plastic red and white covers on the needles , you can take em right off...
Oct 15, 2015 | Husqvarna Garden
2008 Ducati 1098s loss of power
check throttle cable and all wiring
by the way im 11 yrs
Jun 23, 2013 | 2008 Ducati 1098 S
Power loss at full throttle
carburetor main jet 2x, clean the carbs
Apr 30, 2013 | 1986 Honda VT 500 C Shadow
V18 battery loses charge very quickly
getting old... for another $100 you can get a new one. or buy a new drill that uses a ion type batt.
Feb 07, 2013 | Milwaukee Tool V18 Battery
TPS? Car studders at low speeds when climbing hills
YOU HAVE A TORQUE CONVERTER LOCKUP ISSUE, HAVE SOMEONE LIKE THE DEALER,AUTO ZONE OR IF YOU ARE HANDY CHECK FOR CODES, NO CODES....THEN TAKE THE CAR OUT STEADY DRIVE AT AROUND 45 MPH, GENTLY HIT THE BRAKE PEDAL JUST ENOUGH TO MAKE THE REAR BRAKE LIGHTS GO ON BUT NOT HARD ENOUGH TO STOP THE CAR...DO YOU FEEL THE CONVERTER SHIFT IN AND OUT EACHJ TIME THE BRAKE PEDAL IS TOUCHED MAINTAINING A STEADY 45 MPH SPEED, IF IT THAT SAME SHUDDER YOU ARE FEELING THE TORQUE CONVERTER NEEDS TO BE REPLACED, NOT AN EASY JOB AS THE TRANSMISSION HAS TO BE REMOVED TO GET AT IT.SORRY ABOUT THE CAPS.......
Jun 21, 2010 | 1998 Chrysler Cirrus
How to replace right hand throttle grip 2003 ultra
Remove the switch housing screws and spread it away. Loosen the adjuster locknuts on the throttle cables and adjust cables in, this will allow you to lift the cable off of the throttle grip. Be care full not to lose the barrels.( the small round caps on the end of the cable.) Assembly is the reverse. Make sure to check proper operation of the throttle before starting the bike.
Apr 06, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
When at full throttle it feels like it's losing power
definitely a carb. issue......before taking it off and cleaning it try running some seafoam through (sold at advance, autozone etc) the tank.....sounds like the jets are a little clogged
Feb 17, 2010 | 1995 Suzuki GSX-R 750 WS
Yamaha yzf750r missfire rough running
your pilot jets are blocked.they need cleaned or replaced.they are a #35
Mar 31, 2009 | 1996 Yamaha YZF 750 R
I relpaced the fuel lines on my Mccullough Eager ****** leaf blow
ok then these are the low and high speed adjusting screws. first make sure the spark plug is clean of buildup or new . what you need to do is first try to get it to idle with the low adj screw. now im not sure which ones which so try one and if it makes no difference during idle then try the other. start it if it dies turn the screw , repeat this until you get the right sound and steady idle.once you figure out the low screw trun it all the way clockwise then turn it counter about 2 turns. then tune the idle from here. you want it to have a steady sounding idle. now the idle sounds good use the high screw to adjust the throttle. give it about half throttle and turn the high screw until it sounds steady here. then go to full throttle and turn high screw until it sounds steady here. now it should sound steady at idle and throttle. and try not to trun the screws more than 1/8 to 1/4 turn at a time,especially the high, you dont want to blow it up. lemme know how it goes
Nov 16, 2008 | McCulloch 26cc Gas Blower Mcb3208
Video Game Consoles & Games Logo
32 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
