Question about Numark Audio Players & Recorders
How do I get my Numark TT-1510 open to fix a broken wire?
I have a broken wire that needs to be soldered, how do I open my unit so I can get to the wire>
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Numark Master
  • 924 Answers
First of all, how do you know if you have a broken wire if you can't get the unit apart? For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 08, 2013
  • 1 more comment
  • Frances Thomas
    Frances Thomas Dec 08, 2013
    I meant to say that the soder point broke, the wire is attached to the plug which is attached by a plastic case which is broken and has been for years. It has been fixed before but it was damaged when I moved 200 miles away. Why are the darn wires so small in the first place? I do have another one to use that is usb but this one I use to play my worst shape records, the usb turntable plays my primo sounds.
  • Audio Service Clinic Dec 08, 2013
    The wires are so small because they have to be very flexible to keep the tonearm from binding. They don't usually break or tear unless someone has been in there.
    I think it was you that said you had miswired the leads. Just remember, red and green(ground) are the right channel and go together. White and blue(ground) are the left channel and go together.
5 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: NUMARK TT 1625
Any of the following cartridges will fit your turntables:
CARTRIDGES @ 1200s.com
I don't suggest using the originals that came with the turntables, as they aren't of the greatest quality. For a small investment (about $50), you can get some better quality cartridges/needles.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.REPAIRNYC.com
Posted on Jul 15, 2008
djproaudio
  • 515 Answers
SOURCE: pitch trouble numark tt-x1
Either the pitch control is damaged, or your drive system is damaged. Unfortunately for either case, your going to need some professional assistance.
Sorry I couldn't be of much more help.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
  • 69 Answers
SOURCE: Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Posted on Aug 07, 2009
Grubhead
  • 5445 Answers
SOURCE: my numark tt200 turntable doesnt output anything
Have you replaced the cartridge? If you have it might be an internal pre-amp problem inside the deck.
Posted on Nov 27, 2009
How to plug up a Numark tt-1700
Like any other turntable - into a Phono preamp.
Web search "Numark TT 1700 manual". It's at numark.com.
Aug 12, 2011 | Numark TT1700 Turntable
Alright well I have a Numark rack mount dj set with two CDN95 2 disc players. Well I bought it used with speakers and everything and do not know how to plug everything, I really need some help please...
As shown in the Quick Start Guide (link below) this unit should be connected to a Mixer Unit.
http://www.numark.com/stuff/contentmgr/files/0/662529d8e9e5b8ebe1747274e5bad9d6/file/cdn95_quickstartguide.pdf
Looking at the Diagram they appear to be standard AV Cables so you should just be able to plug the CD Outputs into the Amp AV Inputs (as long as it's a Dual Amp) and then connect your speakers to the Amp (make sure the speakers impedance matches the Amp.
Further details available at http://www.numark.com/cdn95?tt=5
Please leave feedback
Cheers
Andy
Apr 25, 2011 | Numark CDN95 2-Disc CD Player
Kyocera mita km 1510 signal code panne c 610 pour quoi
Broken fixing heater wire
• It takes 15 s or more for the fixing temperature to reach 50°C/122°F after the power is turned on or the safety switch is turned off and on.
Fixing unit thermistor installed incorrectly.
Check and reinstall if necessary.
• It takes 10 s or more for the fixing temperature to reach 100°C/212°F from 50°C/122°F.
• It takes 24 s or more for the fixing temperature to reach the secondary stabilization fixing temperature from the primary stabilization fixing temperature.
Fixing unit thermostat triggered.
Check for continuity. If none, replace the fixing unit thermostat.
Nov 03, 2010 | Kyocera Mita KM 1510 Laser Printer
I can't find a needle/cartridge for my turntable, it's a Numark TT-1910
if you have the headshell left with the 4 little wires hanging out then you will need a complete cartridge.
turntableneedles dot com/Half-Inch-Standard-Mount_c_49632.html
if you have the cartridge part then it's still good and you only require a new needle. Type your cartridge number into the search window at the above website.
Apr 24, 2010 | Numark TT1910 Turntable
Jul 18, 2009 | Numark ttUSB Turntable
Tt1520 with broken back phono socket
http://s130.photobucket.com/albums/p278/tattie_boi/?action=view&current=eBayISAPI.jpg
Like this?
How do you plan on reattaching the wires?
Mar 20, 2009 | Numark TT1520 Turntable
My Numark Cdx won't read cds. It just ejects them.
GO ONTO YOUTUBE. TYPE IN NUMARK CDX FIX. Follow the video as instructed and this will be fixed.
Jan 04, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Pitch trouble numark tt-x1
- OPTiC.
www.djprolab.com
Apr 13, 2008 | Numark TTX1 Turntable
149 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
