Question about PreSonus Audio Electronics PreSonus StudioLive 16.4.2 Studio Live
Presonus 16.4.2 bad dsp board
Mixer pop and freezes up. Bad dsp board?
How do I get driver updates to connect with pre sonus software
Not sure what your issue is, as long as you have the ASIO drivers installed you'll be able to get a decent copy of the main mix into and out of presonus. Even if not the standard windows sound drivers will recognise it as an external sound card and you can map this into / out of presonus so you don't actually need ANY drivers other than standard windows ones. If you were hoping to get access to the individual channels to do the mix in presonus forget it, this is not what what your mixer is designed for, get an X32 or other professional mixer.
Mar 15, 2016 | Behringer XENyX 1204 XENyX 1204 12 Channel...
Hi, I have a Mackie vlz3 mixer. Last night I turned everything on and it was all distorted. I did some trouble shooting. It is definitely the board. Can you help. Ted
sounds like it could be dust or moisture ...Try cleaning the board and knobs and faders. this may help it may make it worse. Also while at it...check all connections...especially from board to amps. or to outboard gear. Could be a bad chord
Feb 22, 2015 | Mackie 1604 Vlz3 16 Channel Mixer
SET UP PROBLEM
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Jul 15, 2017 | Mackie Onyx 1640i Mixer
Effects chip how hard to replace
What makes you think the effects chip is bad? It is LIKELY a fine-pitch DSP that is far beyond what the average tech could do. If you could get one, you would have to take this to a shop specializing in surface mount rework. The chances of this chip being bad is very low. More probable is either pilot error or other circuits, especially those exposed to the external connections.
Aug 28, 2011 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
Presonus keeps freezing (does not switch off but no sound is heard through the FOH & Monitirs) every 15 to 20 minsutes
Just getting one of these... hope mine doesn't do this... However I can offer some suggestions to check that you have obeyed the rules of proper connection of music equipment to avoid noise and damage that can occur. FIRST... ALL and I mean ALL interconnected equipment such as amps, mixers, players, and computers, etc. need to be powered from the SAME receptacle or power conditioning module, even if it means running power extension cord. AVOID static discharges to any connected part such as mics, computer, etc.. These can often freeze equipment even though you don't feel the spark. Without knowing your particular setup in detail myself nor most helping people will not be able to offer much more help.
Aug 01, 2011 | PreSonus StudioLive 24.4.2 Digital Mixer
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
On any channel I've begun to get a intermittant
If this has a digital effects processor read on.., I had a SIMILAR problem on a Behringer GX110.
The electrolytic filter cap for the 5 volts of the DSP effects had gone bad. The 5 volts was dipping when the DSP reset and it would repeatedly reset causing a clicking at about once a second. 50 cent part fixed it. The part is a little undersized electrically so is more prone to failure in the unit I have.
That particular one had the DSP as a seperate board with its own 5 volt supply from the main transformer.
Dec 18, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
PreSonus Audio Electronics PreSonus StudioLive 16.4.2 Studio Live Logo
75 people viewed this question
Top PreSonus Music Experts
Norma Garcia
Norma Garcia
drivealot
Are you a PreSonus Music Expert? Answer questions, earn points and help others
