Question about Craftsman Saws
Bandsaw loses power
When I turn on the saw the motor won't get up to speed, and it seems to be vibrating quite a bit. And when I put wood thru it slow Dow to nothing, please help!!
    Sergeant:
  • 468 Answers
You neeed to check the motor, capacitor, drive pulleys. Check thoroughly if there are loose set screws, loose
tires or sqealing bearings.
Change the belt out for a link-belt so you don't have any stiff areas causing a vibration when they hit the pulleys.
Poorly balance wheels or worn tires are another cause of excessive vibe.
The motor can be not effective anymore, you should get more powerful motor. Try to call Tech Support too.
Posted on Nov 27, 2013
  • 10865 Answers
SOURCE: What size a step pulley required for the motor ?
rpm_chart.jpg?t=1236890602
here is the chart you need to answer your question. please mark this as a fixya! thanks
Posted on Mar 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Posted on Apr 22, 2009
efs_perpends
  • 1996 Answers
SOURCE: manual for Rockwell 52-235 14'' bandsaw
I don't know how old that machine is, and I can't get any hits on the model number you gave, but have a look at this link and the other Delta/Rockwell bandsaw manuals available at the same site, and you may find something that you can use. Go to machine info>publication reprints>and choose either Delta or Rockwell, then you can filter the results by bandsaw and see what's available out there. To download, just click on the blue letters PDF under the publication preview picture.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
  • 4090 Answers
SOURCE: 14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Posted on Aug 29, 2009
  • 909 Answers
SOURCE: Saw seems to lose power even when trying to cut
Tensioner worn or mal-adjusted.
Blade blunt.
Posted on Jan 02, 2010
Adjusting the speed on a Hafco Woodmaster 10 inch bandsaw
band saws have an alignment adjuster that allows the line up (plane ) of the pulleys to prevent band run off
next . if the band is too tight , go to a saw sharpening shop and get a new band made that is longer
after all different woods need different number of teeth (pitch) to prevent burning of the wood due to hardness of the wood
of course you could always consider getting a motor that has 1/2 the rpm rating that you currently have
May 25, 2018 | Miscellaneous
Slows down and stops when trying to cut hardwood
You just do not have a saw that has enough power, the blade is dull or both. Change your blade and push the wood through slower or get a more powerful saw for the hard woods.
May 11, 2016 | Delta Saws
How can I cut wood 3.5 inches thick with Dewalt Scroll saw?
nope... throat on scroll saw is of fixed height... beside, all scrollsaw blades are of fixed length, i would suggest use of bandsaw with very narrow blade with minimal kerf. do not use pressure on the blade! you will then have same cut through the thickness of the wood! setup bandsaw correctly, do not overtension it - see my other instructables pertaining to the bandsaw and regulation/setup of it
if you find my solution helpful - do not me shy... give some points... :-)
Jan 23, 2014 | Dewalt DW788 20" Variable-Speed Scroll Saw
Blade stops when feeding wood
It may be that the motor is under powered for the load, but more likely it sounds like the motor is defective. Perhaps some of the windings have shorted. That might allow the blade to spin, but stop under any load. What brand and model is this saw?
Jan 30, 2018 | Bosch 4000 - 07 Electric Table Saws
Reduce bandsaw speed to cut metal
My old delta has the transmission on the back for cutting metal, and it is geared way down for power, 1140 would be way to fast, It is more like 40 rpm. I don't know if even a set of step pulleys would slow you down enough. Depends on the metal. I have the step pulleys too, but never bother to change them. The transmission, you just pull out the lock in the center of the pulley and it throws it into back gears. real nice, has an oil filled gear box on the bottom. Everybody wants my band saw!
Feb 23, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
Bandsaw stops cutting
the pressure you are pushing could be too hard or a dull blade. what is the HP of it? I use one for cutting metal bar up to 6 inch and wood. the HP of mine is 15 horsepower and wood will cut quick when solid steel is very slow. of course mine is industrial size with a 3 foot depth
Feb 21, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
Saws Logo
85 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
