Question about Yamaha Rx-v365 A/V Home Theater Receiver
I have a yamaha rx-v375 receiver that has a sony blue ray s3100 plugged in to it. This feed into my optoma dlp projector. but it keeps cutting out and comes snowy and static. It is like it is loosing its signal. What can I do to fix this?
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
SOURCE: Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Posted on Jan 10, 2009
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
easyq
  • 144 Answers
SOURCE: on zone 2 of my yamaha rx v663 receiver it says fixed when I try to adjust the vlume and won't let me cut it up or down.
Check the setup menu of the receiver on zone 2 settings most likely the error is a fixed volume setting for this zone. If not found, reset factory settings and try to setup everything again. If the problems persists, contact your vendor if still under warranty.
Posted on Apr 17, 2009
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
Apr 13, 2014 | Yamaha RX-V375
Yamaha RX-V471 3D video for blu ray will not display on TV
Your Yamaha is the problem here. It cannot handle the signal and process the 3D as it states. What I would do is hook your player direct to your TV in the manner that it works and feed your audio from a different path to maintain surround system. Your tv/dvd player may have an audio out that you can feed back to the Yamaha .
Jan 11, 2014 | Yamaha Rx-v471 3D A/v Receiver
I have an optoma tx1080p projector and Yamaha receiver. Recently we started getting the problem where the projector keeps saying that the source is not found. When I connect the hdmi cable directly to the...
This is most likely a problem with what's called "HDMI handshake." It's a silly protection scheme called HDCP that is meant to keep people from copying content. The best thing to do is unplug everything, then turn on things in this order: receiver>projector>sources (directv, Bluray). If that does not work, check for firmware updates for the receiver or projector.
Oct 29, 2013 | Audio Players & Recorders
Yamaha RX-V375 turns off during periods of heavy subwoofer/base sounds. Sometimes it turns itself back on, other times not. Help!
most likely you're hitting the clipping or the threshold of the power.
the other possibilities is you have a small short there.
one way is unhook our speakers, tidy the cable u and hook it back to make sure there are no shorts.
if this does not solve the problem then you just might be hitting the limit of your receiver which the only way is to change receiver or your speakers to match them
Oct 27, 2013 | Yamaha RX-V375
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
I have a DLP Optoma projector. It's a few years old. When my wife and I turn it on, it usually shuts down after about 20 minutes of use. what can we do to solve that?
clean it out. it may be dusty inside. the dust keeps in the heat, and if the projector can't cool down, it cuts the heat source- the lamp. also see if the lamp is close to 2000 hours. it may need replacing.
Aug 10, 2009 | Optoma HD65 DLP Projector
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Dec 29, 2008 | Yamaha RX-V1700 Receiver
Yamaha Rx-v365 A/V Home Theater Receiver Logo
101 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
