Question about Weather King 10AJA2501AH Air Conditioner
Fan does not work on heat mode - Weather King 10AJA2501AH Air Conditioner
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 29 Answers
If the fan works on AC mode, then it is most likely a problem with the ignition system. There is a safety feature that shuts off most everything if the heater does not sense ignition. It could be the ignitor, the sensor, or the main control board. Look for a blinking red led light. It will give you a trouble code to start with. If you don't feel comfortable with electricity, don't mess with it. Call for professional help.
Posted on Nov 25, 2013
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
Remote start is set for a/c, how do I change it to heat
There are symbols for each mode. Fan leaf for fan mode. cool mode indicates round star. and Sun symbol represents for heat.
Plz note if you change mode heat, it keeps memory and when you switch on again, then the same heat mode will work.
Tnx
Nov 16, 2013 | Heating & Cooling
Rent a house with a daikin brc1c51/61 with no instructions on how to work control panel for cooling/heating
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.For further details, plz:
www.devicemanuals.com/guide/.../Daikin-manuals.html
Dec 30, 2010 | Heating & Cooling
I have a brand new york inverter air conditioner that does not want to cool!
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Dec 29, 2010 | Heating & Cooling
When heater is on the fan turns off. when we switch the fan on the heat element turns off but fan comes on. one or the other works but not both at the same time.
In some unit heat mode will start the fan after few seconds. Wait for max 3 minutes. If you turn it to fan mode, fan will only work no cool or heat will respond.
Dec 26, 2010 | Heating & Cooling
Oven does not heat up in fan oven mode but fan runs. works fine in convection mode. Baumatic B723SS-A
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Dec 17, 2009 | Baumatic Ovens
Dometic ac/heat pump
Would suggest it is drawing excessive current, make sure both fans are going, (inside will cycle low/high), or possible faulty reversing valve solenoid, or could be as simple as loose wire connection, how long does it run for and is it on the same 20amp breaker as the rear?if so start by running only the front unit in cooling 15/20min, check fans running, no unusual bearing noises, switch off for 60 sec then back on heat mode, if unit runs without stopping rewire onto separate circuit, if inside fan not working on heat check bi-metal switch in the airway, if running for a while, fans going but not very warm, check reversing valve.
Note, electrical's should be tested by someone who are qualified in the field.
Nov 05, 2008 | Dometic Rooftop RV Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
