Question about Thule 2003 Chevy Tracker - 4-door, without factory roof rails - Base Rack System
Won,t shift out of park
Auto trans I step on break peddle will not shift out of park I let run 20-30 min still won't shift it did just fine day be-4 it was warmer in 20s today
    Problem Solver:
  • 8 Answers
Possibly blown fuse due to short in electrical circuit.
Posted on Nov 28, 2013
My Isuzu Rodeo won't shift into any gear besides park or neutral.
if the car is a auto matic start the car in park with the parking break on. under the hood you will see to dip sticks. one should be black "oil" the other yellow Transmission stick. with the car running pull the dip stick out wip off any oil on the stick. reinstall all the way pull it out again, you should have either 2 dots aproxmaintley 1" spread the top dot is where the trans mission fluied needs to be. if it is barley on the stick go to your local parts store ask what type of transmission it uses and buy a couple of quarts probley about 12.00 also get a tran. funnel to add the fluied. put a little at a time and check the stick untial it is on the top mark about2.5" from bottom of the stick. also if the fluied is not a redish color, have it changed. good luck
Nov 17, 2013 | 2000 Isuzu Rodeo
F250 1998 light duty won't shift out of park
For car not changing gears and not shifting out of park mode ,it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
NO REVERSE ON TRANSMISSION
http://alltypesofpartsreplacing.blogspot.com/2012/12/no-reverse-on-transmission.html
Transmission fluid leak, transmission gears slip,
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-fluid-leak-transmission.html
These will help.
Thanks.
Dec 06, 2012 | 1998 Ford F250 SuperCab
2007 HHr auto transmission won't shift properly
Check the auto fluid level when cold. The level increase when warm. with any luck its just low fluid.
Jun 28, 2012 | Chevrolet HHR Cars & Trucks
1995 Olds cutlass supreme. Can't shift out of park. Couple of times before it did this but after fiddling around it released tiself and shifted. Today no luck.
Hi:
Ther is a small switch on the back side of your break peddle arm at the fire wall. an automatic transmission will not shift out of park whithout stepping on your break while shifting out of park. I would bet that switch is going out and that is what is causing your intermittant problem. shouldn't be too mutch to have it replaced. Good Luck...
Aug 08, 2011 | 1995 Oldsmobile Cutlass Supreme
93 honda accord the automatic trans wont shift auto but works great shifting manually, how do I fix it
your having a transmission problem,common problem are the shift solenoids get dirty and won't let it shift,have them taken off and cleaned,they have little screens on bottom of them.change the fluid at same time. clicking noise is normal when you step on brake when in park this click is from the interlock solenoid under center console.
May 25, 2011 | 1993 Honda Accord
Steering, key and breaks all locked up!
If you have another key, try it! My first thought is that you have way too many keys on the fob. This will do a number on your key switch!
Also move the gear shift from low back to park. Step on the brake peddle as well.
Mar 28, 2010 | 2004 Buick Rendezvous
When trans. is warm after extended driving the up shifts are very hard. This only happens during extended driving periods. Around town everything shifts fine.
Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check Throttle Position Sensor (TPS) for smooth electrical response. If the response is jumpy or erratic at all, replace TPS. Good luck Auto Zone or Parts Source has this part and can be replaced with in 20 min. Both parts store will have the step by step instructions and i believe the cost is around $65.00 for the TPS which is better then a transmission replacement.
Nov 30, 2009 | 2000 GMC Yukon XL
Can't get car out of park!!
This may seem like a silly solution but it's worth a try if it gets you out of this jam. I believe the Kia has a safety feature where it won't let you shift the car out of park unless the break peddle is fully depressed. Try stomping on the break peddle while you start the car. Then see if it will let you shift out of park. If this doesn't work try pumping the break peddle a few times and try it again. If this doesn't work check the fuse box. Maybe the fuse for the actuator in the gear shift lever that lets you take it out of park is burnt out. I hope this helps you out.
Jun 03, 2009 | 2006 Kia Optima
Thule 2003 Chevy Tracker - 4-door, without factory roof rails - Base Rack System Logo
52 people viewed this question
Top Thule Cycling Experts
Audrey Messer
Audrey Messer
dante
Robin Brighouse
Robin Brighouse
Are you a Thule Cycling Expert? Answer questions, earn points and help others
