Question about Sur La Table Remote Roasting Thermometer
Linking remote unit - Sur La Table Remote Roasting Thermometer
Hi I have a Bauhn AC42 F22 which the remote has been broken and have bought a new remote but can not find the code for the new remote . Appreciate your assistance . David
Better to buy a facsimile remote
bauhn - Remote Control Warehouse
https://www.remotecontrolwarehouse.com.au/bauhn-c185
Add to Compare. REPLACEMENT BAUHN REMOTE CONTROL - ATV185-014 AT215D-0216 ATV32-715 ATV32H-014 ATV32H-1215 ATV40-014 ATV50-014 ATV50-715 ATV50F-415 ATVU65-0916 LCD TV. Generic BAUHN REMOTE CONTROL Unit: ATV-32HDC1N Suitable for BAUHN Models: .. $38.50. Ex Tax: $35.00.
REPLACEMENT BAUHN REMOTE CONTROL - ATV185-014 AT215D ...
https://www.remotecontrolwarehouse.com.au/replacement-bauhn-remote-control-atv1... Generic BAUHN REMOTE CONTROL Unit: ATV-32HDC1N. Suitable for BAUHN Models: ATV-32HDC1N ATV-24LEC3 AS-39FHD1 ATV-50FHD5. ATV185-014 AT215D-0216 ATV32-715 ATV32H-014 ATV32H-1215 ATV40-014 ATV50-014 ATV50-715 ATV50F-415. ATV40-1014 ATV40-1015 ATVU65-0916 ATVUHD55- ...
Or their own Universal Remote
http://winplus.com.au/links/UR39677%20Bauhn%20Universal%20Remote%20Manual.pdf
The Codes are in the PDF File
http://winplus.com.au/links/UR39677%20Bauhn%20Universal%20Remote%20Code%20Book.pdf
Mar 14, 2018 | Televison & Video
Find a remote control
Hi
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Thank you
Sep 20, 2008 | Zenith XBV443 DVD Player/VCR
I have two of these units with remote located in one room. All of a sudden, both remotes work the same unit. How can I "reprogram" one of the remotes to control the other unit?
Here is a link to the service manual for your unit. Look for section on programming unit identification for the remote.http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.quietside.com%2Fclassic%2Fdownloads%2FService%2520AQV18_24%2520JAKCV.pdf&ei=uwh1U5PpNM6iqAaHr4DQCA&usg=AFQjCNEAs6FdSrr1lSDgNuNZ_9zvmycdKA&sig2=pILXHK1-yJa9ugqScI1evw&bvm=bv.66699033,d.b2k
May 14, 2014 | Samsung AQV18JA Classic Wall Mounted Mini...
I have a hauzen wall (ducted) fan/air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an...
i have a hauzen air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an orange button to turn on and off... can you send me an english manual link? the wall unit is about 3 feet and also has a grey button on the right front bottom unit to turn it on and off. above that on the front right flat side are 5 small round lights that let you know how you have the unit set. hope this description helps you understand what kind of unit i have... i cannot read korean to be more clear. i would appreciate it if you can send a user guide in english. thank you
Jul 24, 2011 | Heating & Cooling
I have a Panasonic DMR-BW880 in New Zealand, expecting (for the huge amount that it cost) it would play DVDs from all regions. But it won't. Can you tell me an unlock code and how to use it please?
Hi.
This player region hack is done programming a service remote, then using the programmed remote on the unit to unlock the region. There is no way to unlock this unit using buttons on the original remote, or on the unit.
You can purchase a programmed remote kit using the link below:
Region remote kit DMR BW880.
Regards.
Ginko.
Feb 20, 2011 | Panasonic Televison & Video
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote codes for a urc - 4640B00 one for all , can you help?
Your unit is a discontinued unit however you may click on the link below for remote codes for the 4600 series.
http://www.hifi-remote.com/ofaold/acc3cod.html
Nov 22, 2008 | One For All URC-3021 Remote Control
Dish Network remote control unit malfunctioning problems
Hi Monell56 my name is Mike Houston of DISH Network, with the DISHNetwork remote and replacing the batteries in the remote you will press andrelease the SAT button and press select on the remote. If the SAT button didnot light up the remote will need to be replaced. If the SAT button lights uphere is the link that will help setup the remote. http://www.dishnetwork.com/SupportSection/remote-setup
Dec 04, 2007 | Televison & Video
Sur La Table Remote Roasting Thermometer Logo
61 people viewed this question
Top Sur La Table Home Experts
john h
Tom Chichester
Are you a Sur La Table Home Expert? Answer questions, earn points and help others
