Question about Dryers
What size dryer is this nvlr333etowb - Dryers
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: hotpoint nvlr333etowb no heat.
Diode? Ain't no diodes. 3a90295.jpgIf all of theses items check good you might have a burred contact inside the timer. These dryers have a timer that is easy to take apart. Gently remove the motor and cover, look for a burr between the leaf switches. File em down smooth. Let me know.
Posted on May 08, 2010
I have a Hotpoint Dryer NVLR333ETOWB, I opened the door mid cycle, to check on load, make sure it was drying, I shut the door, and when I turn the start knob, all I get is a buzz, and the dryer does n
Hey GOD IS GOOD !!!!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Sep 29, 2014 | Dryers
I need to replace my heating element for my dryer. The model number nvlr333etowb. how do I replace it and where is it located?
Greetings,
the first thing you do is remove the top...sometimes there is two screws going up from inside the door....or just pop the top using a putty knife.....there are two screws on each corner of front, remove these and you can set the front aside or disconnect the wiring at the door......next, you will need to remove several screws that hold the cabinet to the frame. this allows you to move the cabinet slightly to get the drum out....next, reach in and remove drive belt..pay attention how it goes before removing...ater the belt is off, you can actually slide the drum out of dryer....located on rear bulkhead is the heater. the best thing to do for you is to replace the complete pan assembly...or use a re-string kit...reverse order in putting back together
Dec 14, 2010 | GE DPSR610EGWT Electric Dryer
Hotpoint nvlr333etowb no heat.
May 08, 2010 | Hotpoint NVLR333EE Dryer
My hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Oct 24, 2009 | Hotpoint NVLR333EE Dryer
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
I have a hot point dryer, mod#NVLR333ETOWB, i have taked the dryer apart and unpluged the element and checked continuity and i get a solid continuity tone. i put the dryer back together and still the dryer...
Have you checked to make sure that the breaker for it is good? Have you checked to make sure that the wires are tight going to breaker? How old is the house?
Jan 27, 2009 | Hotpoint NVL333EY Electric Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
I have the same dryer doing the same thing. Open the door and take the two screws out and lift the top. Remove the two screws that hold the front on. Remove the front. On mine both the plastic parts that stay on the front when it is removed are cracked and needing replaced. I found over 20 buttons that the dryer had pulled off clothes stuck in the front door. I'm sure if it will be cost effective to buy both these parts or not.
Jan 13, 2009 | GE DBXR453EV Dryer
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
PROBLEM WITH HOTPOINT DRYER
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1811&modelDesc=DRYER&modelNumber=NVLR333ET0WB&documentID=E2136683&documentTypeID=PLDM&documentClassCode=PV&titleType=DRUM%2C%20BLOWER%20%26%20DRIVE%20ASSEMBLY&titleID=00004&
This is a diagram of your particuliar unit. These Hotpoints are manufactured by GE. The heating element is right behind the drum itself. First is to unplug the unit. Open the door, and look at the top edge of the top of the door. You will see two screws that hold the top down. Remove these screws, then lift the top off. You will have to reach your hand under the drum (and really reach around) and unhook the belt from the idler pully and motor pully. The drum is now free to pull out, directly forward. Your heating elements are now right in front of you. Be sure you check both for drooping, touching each other or the sides, broken wires, etc. Also, these elements are very, VERY expensive. They make a rewire kit that will save you a TON of money. Instructions are included with the kit, Be sure when you put the drum back in, you grease the rear bearing slide and plug.
Heater Assembly (whole unit) Part Number WE11X103 $90.00
Restring Kit: WE11X203 Part Number $35.00
Also, both of these parts are usually found on E-Bay in groves. Do yourself a favor, do not buy them from Sears, they have too high a mark-up, shipping is also way to high, and takes forever to get there. Let me know if you need further help. Thanks and good luck!!!!
Feb 02, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
