Question about Coleman Heating & Cooling
My coleman fl28-r has a similar problem as well except i have found that the fan does not have enough power to start spinning. therefore it causes the unit to shut off. is this a problem related to the magneto that spins the fan
    Top Expert:
  • Coleman Master
  • 8,673 Answers
Either bad start up capacitor or motor
Posted on Dec 07, 2017
  • 161 Answers
SOURCE: RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Posted on Jul 04, 2008
geemarie
  • 876 Answers
SOURCE: WMA64 will not spin on spin cycle only
Check you drain hose for obstruction.
Posted on Aug 20, 2008
neogil22
  • 36 Answers
SOURCE: Maytag model LA- 510 washer.
the cluncking sound is not a brake system since there are no brakes, but the stabilizer of the drum. as when it stops turning the whole weight of the drum 'hangs' on the stabilizers. That might also be the problem with not spinning fast enough, although I think that its not spinning fast enough because there's too much water inside. I would check the drain hose and drain filter, either one of these two are clogged up, and therefor not letting the water out.
hope you'll find the problem soon.
friendly greetings............Gilbert.
Posted on Mar 08, 2009
crouchdash
  • 83 Answers
SOURCE: Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
Posted on May 21, 2009
  • 66 Answers
SOURCE: unit comes on fan does not spin
your capacitor on the fan side is blown but that particular model needs a dual capacitor. Don't run the fan too long like that you will overheat the windings and melt her down.
Posted on Jun 30, 2009
Why is my coleman mach squeaking
Our AC did this and needed bearings replaced. Cost $10 dollars to fix it. Husband did the work. Took him less than an hour to replace the bearings.
Jul 10, 2012 | Coleman Mach III Air Conditioner
My 2000 camry engine shakes when idling
my 2000 camry also shakes when idling. Looks like the radiator fan is culprit, but havent had time to change out yet. looks like old blades on fan broke off making it unbalanced when spinning to cool off causing excessive shaking. When driving its cool enough where that particular fan motor does not need to spin, therefore no shaking. possible solution is replace the fan that is wobbling.
Nov 27, 2011 | 2000 Toyota Camry
Motor starts but wont turn
If it hasn't been running for a while, try going up on roof (AC in off position) and using a stick, or similar piece long enough to slide it through air slots in cover and spin fan blades a few times. It may only go a little at a time but keep going until you make 2 or 3 rotations. Then remove it and have someone try fan mode only. If it runs, let it run for a few minutes and , from then on it should be o.k. If you can't get at it to spin it enough with stick, remove screws on top of cover and remove cover and spin by hand (carefully and power off to AC), then try to start it. If motor hums but still will not start by itself, have capacitor replaced. Very dangerous to handle so either have someone who's familiar with capacitors do it, or a technician.
Feb 24, 2011 | Coleman Mach III Air Conditioner
Ga-m55sli-s4 dead i was using it last night and switched off and morning when i tried to start my computer i got not display at all i checked powersupply and all but found that the board itself was dead...
I am not sure how you checked the power supply but they can be misleading. Many failed power supplies still have enough power to turn on lights and spin fans but not enough for a system startup.
Unfortunately, MB's are not designed to be serviced. Considering 1 or 2-hours of labor costs more than most motherboards these days it is just not worth trying to fix them. Therefore, if it is not the PS you need to buy a new MB.
Aug 12, 2010 | Gigabyte GA-M55SLI-S4 Motherboard
My walkman works when its plugged in but as soon as its unplugged it goes blank and i cant turn it on?
Try plugging it in to a mains charger! I had similar problem found this on sony website -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
  1. Battery must not be discharged 100%
  2. If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Mines back to full working order!
Jul 18, 2010 | Sony Walkman NWZ-A828 Digital Media Player
It wont turn on or charge what and why??
Are you trying to charge it through the computer? If so try through a main charger! I had similar problem but found this on Sony website -
Cause:
Remedy:
Jul 15, 2010 | Sony Walkman NWZ-A828 Digital Media Player
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
