Question about Dryers
No heat 2004 545i..replaced thermostat. Noe what
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Ohm the heat element it show infinity if not replace also check power has to be 220v, most dryers have a thermal fuse that is one time fuse if that has an open circit it will not heat .
Posted on Nov 25, 2013
My car overheated noe it won't start
need to know what make and model but if is a 6 cylinder engine or smaller it most likely has serious damage from over heating
Feb 11, 2018 | Cars & Trucks
How do I take apart kenmore model # 417 94812301 and change thermostat
ahhh? if u donot noe how to take the back off?, how do u think u will be able to cxheck the thermostat?? call a pro, and stay allive!
Feb 28, 2014 | Kenmore 98702 Stacked Washer/Dryer
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
Sep 30, 2012 | Honeywell Programmable Thermostat Heater
When i bought my 2002 galant the heater core had been bypassed and i connected the hoses and it still still blew out cold air. I replaced the shut vavle and it corrected the problem. Noe ive noticed...
Not likely.. Check the bolts at the thermostat... most likely didn't get them tight enough..tip of you replace a thermostat always buy a fail open thermostat .. Fail close ones kill more cars then you would believe.
Feb 20, 2018 | 2002 Mitsubishi Galant
Changed water pump in 06 dodge 1500, 4.7 v8. Everything checks out except noe my engine overheats, not getting any flow either. could it be the thermostat?
it could be thermostat or it could be a blown head or valve gasket does your oil look like coffee with cream?
Nov 18, 2010 | 2006 Dodge Ram 1500
I had new intake manifold gadket installed noe
Since problem developed after head gasket replaced. I would look at head gasket. Try re-torque head bolts. Was correct gasket size installed? (due to wear and tear, sometimes OEM gasket is no longer correct).
Jul 09, 2009 | 1997 Lincoln Continental
Heating
your condensing unit shoould run when the heat is on. Noe what is the temperature of the discharge air at the grilles. If it's really cole then the reversing valve may not be working correctly and you may be ablre to go to emergency heat only until you get a technician out to see why.
Dec 22, 2008 | Weather King 12AJA6001AH Air Conditioner
Overheated , now fixed but have no powe
You may hae a non-resettable thermal fuse that opened.. when that happens.. system won't operate..
Sep 03, 2008 | Whirlpool LEB6300 Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
