Question about Minolta DI2510 Black and White Copier
"please wait" error appears on diplay when i turned on the mfp
  • Minolta Master
  • 6,696 Answers
Sir, Mam, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything unit the F8 is run. Or you start over again with new developer and new drum
Posted on Jan 22, 2015
Testimonial: "It is corect what you said but in this case was not the problem with the developer and the drum....the problem was Ethernet Board."
  • Norman  J Weimar Jr
    Norman J Weimar Jr Jan 23, 2015
    Glad to hear it. Up and running is the goal!:)
ERROR E7 IN HP LASERJET PRINTER M1136 MFP
HP M1136 printers doesn't have E series errors, pl chk
Mar 15, 2014 | HP Office Equipment & Supplies
Have you had the develop and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready To Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can not print anything unit the F8 is run. Or you start over.
Nov 24, 2013 | Minolta DI2510 Black and White Copier
Error 79
Hi. This is a firmware related issue.
First check if the firmware posted on HP website for your MFP is newer that the one you currently have, if it is then download and apply the newer firmware.
In case the problem persist, you could also try the following troubleshooting:
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the MFP to fully initialize.
If you have recently installed a memory module in the MFP, turn off the equipment, remove the memory Module, reinstall it and verify that it is seated properly, and then turn on the MFP.
If a surge protector or no-break is being used, remove it. Plug the MFP directly into the wall socket. Use the power switch to turn the MFP on.
If the error persists, contact HP.
Oct 19, 2012 | HP LaserJet M1522n MultiFunction Printer
Fuser error on lexmark c543, what is it and how do I fix it? Thanks
Fuser error indicates that the printer/MFP has detected a problem with the fuser unit.However, certain rare occurrences, such as a power fluctuation or a static discharge in the vicinity of the printer/MFP, can cause a false error messages to appear.
1) Make sure printer is plugged to wall
2) make sure printer has been in turned on in ambient temperature for 30 min. 3)Power off the printer/MFP, wait 30 seconds, and then power it on again. Did the error message return? 4)If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector, extension cord or uninterruptible power supply (UPS), can generate false error messages. Verify also if the printer works on a 110 or 220 volts source. Make sure that the power outlet matches its working voltage rating.
If you still get the error message, I suggest you contact Lexmark Technical Support.
Oct 31, 2011 | Lexmark C543DN Laser Printer
I HAVE A FUSER ERROR 122.06,122.05 AND 122.06 ON A LEXMARK C540 HOW DO i CORRECT
A 122.05 or 122.06 Fuser error indicates that the printer/MFP has detected a problem with the fuser unit. A service call will probably be required to solve this issue. However, certain rare occurrences, such as a power fluctuation or a static discharge in the vicinity of the printer/MFP, can cause a false 122.05 or 122.06 error message to appear. In such cases, the error is only temporary and can be easily resolved without service.
Try perform the following steps:
  • Power off the printer/MFP, wait 30 seconds, and then power it on again.
  • If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector, extension cord or uninterruptible power supply (UPS), can generate false error messages. Verify also if the printer works on a 110 or 220 volts source. Make sure that the power outlet matches its working voltage rating.
If this doesn't resolve the error, I suggest you contact Lexmark Technical Support.
Oct 17, 2011 | Lexmark C540N PROD SPECS TBD Printer
Tengo un problema con la impresora hp modelo m4345 mfp, la cual ya estaba funcionando pero de repente envio un error el cual es el siguiente 49.4c02 - error para continuar apague y encienda , ya lo...
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Jul 14, 2011 | HP LaserJet M4345 MultiFunction Printer
Hp laserjet 9050n appear disk not initialized .how to solve. thank you.
Turn off printer
Press and hold PAUSE/RESUME(START on MFP)
Turn on printer
Keep holding the PAUSE/RESUME or START until all 3 error lights light
Release the buttons
Press LEFT ARROW(5 button on MFP) until INITIALIZE DISKS appear
Press the CHECK(6 button on MFP)
Wait for printer to READY
May 11, 2011 | HP LaserJet 9050 Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
MFP on.
computer.
5 Turn the MFP off.
8 Turn the MFP on.
device.
the error message.
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
Minolta DI2510 Black and White Copier Logo
73 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
