Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Mixer speed surge?
When mixer is on speed #9 it tends to 'stutter' but this only happens speed #9
  • tyler
    tyler Nov 29, 2013
    thanks for the suggestion ross. however over the holiday i actually got a chance to use the mixer and idk where she got the symptoms she described but she just has the classic no difference in speed between 8&10 therefore she just needs an adjustment
  • KitchenAid Master
  • 1,248 Answers
Remove the power and undo the brush caps on the side of the motor and check the brushes. They only go in one way, one corner is chamfered off and must be lined up with the little blocking lug inside the bottom of the brush holder. You may need a torch to look in there. I'm not so sure that this will be the solution but well worth a look.
Posted on Nov 26, 2013
2 Suggested Answers
ricardok45
  • 135 Answers
SOURCE: k45ss kitenaid mixer surges at low speeds
Hi. Go to mendingshed.com and download their free Kitchenaid Service Manual. This valuable document will help you to tune up your mixer, and covers the K45SS model. They also sell kitchenaid parts.
Go to kitchenaid.com and search for a parts manual for your mixer. Enter your model# thusly k45sswh.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Posted on Apr 14, 2009
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
I have a Hobart KitchenAid Mixer Model K45SS and it runs fast on low (Surges speeds up and down)what is causing this problem
Hello Mayfix,
The problem with your mixer is the speed control switch, this switch is located at the back of the unit. It is usually black and has all of the wires coming into it, the Item # 1394070 and cost $27.95 it can be located at RepairClinic.com he is a link
http://www.repairclinic.com/Kitchenaid-Switch-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
You will have to adjust after you install you will adjust the two screws at the top of the switch while the machine is running inorder to make sure that you are getting all the speeds. Be careful as there is a possibility of electrical shock if you touch the wronge thing.
Thank you for using FixYa.
Jul 04, 2010 | KitchenAid K45SS Classic Stand Mixer
High speed all the time
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208204525.pdf
It is either the hall effect sensor item #9 or item #8, the speed control circuit board. Both can be found on ebay, the sensor for around $5 and the board for around $30. Unfortunately there is no simple test for either part.
Take the machine apart and look at the board where the control know is mounted to see if there is anything obviously cracked or broken. If the mixer was ever dropped on its side this could happen!
Apr 14, 2010 | KitchenAid KT2651X Epicurean Stand Mixer
My mixer revs up full bore and then quits, on any speed level
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208211761.pdf
has the breakdown of the parts. Item 8 is the controller board and item 9 is a sensor which monitors the speed. If either one is fried it will run wide open and then quit.
Mar 25, 2010 | KitchenAid 400 Watts KN15E1X Accolade 400...
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
K45ss kitenaid mixer surges at low speeds
Apr 12, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
56 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
