Question about GE Refrigerators
Refrigerator digital panel stopped working - GE Refrigerators
    Problem Solver:
  • 16 Answers
Main control pc bd
Posted on Nov 25, 2013
Control panel
Its faulty control panel, needs to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
Samsung RSH1DBBP Digital Display problem
The display panel has damaged. It has to be replaced by same type and number. There is no repair to it. OK.
Feb 01, 2012 | Samsung RSH1DBBP (19.1 cu. ft.) Side by...
Stopped working
I had the problem with a totally different refrigerator but it was the fuse on the printed circuit panel mounted in the back of the refrig.
Nov 20, 2011 | LG LSC27910 (265 cu ft) Side by Side...
Front door dispenser panel stopped working, lights are off.
HI. the dispenser circuit board(s) will need to be replaced. there are two boards that work in unison. replace them both. this will fix your issue.
May 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Not working
Drain is stopped up or the refrigerator is not defrosting. Look inside the fresh food compartment near the control panel or below control panel for a small hole that you can put a pencil in and turn the defrost timer clockwise until refrigerator stops and remain stopped for about 20 minutes. Need also after you do this let me know so we can go from here, Thanks Sea Breeze
Apr 23, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Samsung rs20ccms fridge and freezer stopped working
I have come across this problem too and understand it is a fault with the back plate which Samsung have now modified.
Jan 23, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Front Door Digital Control Panel keeps cycling
Though I received no FREE support from FixYa (as advertised), after a restless nights sleep I figured out what to do, as I discovered in the morning my refrigerator had indeed stopped running.
Just to provide some background info, this new Kenmore refrigerator was larger than the one it replaced, however I managed to accomplish a near impossible task and squeeze it into the same space, thus it was there to stay, because moving it in and out again was an unlikely task.
Back to the solution. I decided I should try turning the refrigerator on and off. Since I could not locate any controls inside the refrigerator which would turn it off, my only option was to pull the refrigerator out of its very tight space and unplug it, which is exactly what I did. After 60 seconds I plugged the refrigerator back in and ta-da!!!, it refrigerator started running and the control panel stopped cycling and held the initial settings.
I have to admit, I have not attempted to push the refrigerator back into its space, as that is not a feat I'm ready to face.
I hope this common sense solution helps others in need, although they probably will figure it out on their own much faster than I did.
Have a GOOD day!!!
Regards,
Ann
Nov 22, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator failed keeping food cold, ice maker stopped working
i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Nov 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Side by side frigidare brand refrigerator model#frs6b5eew3
Check this out it may help you http://appliancehelp.hypermart.net/xmb_ge_arctica_sxs.pdf
May 13, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
